hey guys i thought i would share my joy with you all, im not saying this will work for everyone, but i had EXCELENT results. i have an r32 rb20 with mild mods, running rich as hell (like most imports) and i was getting between 250-300 k's per tank of fuel. the other day i had some spare time (and was pissed off with shit fuel consumption) so i did 3 VERY simple things to try and fix this....AND IT WORKED for my engine anyway, and i kid you not i have got between 400-450k's out of each of my last 3 tanks of fuel.
1-new plugs. mine were grubby, but nothing crazy
2-thourough cleaning of AAC vavle (this helped clean up the idle as well)
3-i added a bottle of LIQUI MOLY fuel injection cleaner (it takes 1 full tank of fuel before full results are achieved, it wasnt instant)
these 3 simple things have saved me money on expensive PULP and cleaning the AAC valve (somthing everyone should do anyway) smoothed out my idle too!
anyway just thought i would let you guys know, as poor fuel consumption is somthing that most skyline owners know all too well about, and i had such good results with these 3 simple maintenance procedures. cheers adam.
https://www.sau.com.au/forums/topic/278313-almost-doubled-fuel-consumption/
May I also recommend, if it hasn't been done in the last 50,000km, that you change your oxygen sensor. This alone added 80/90km of mileage to my normal petrol usage.
oh f**k im so retarded. lol can i edit the title?
Yep, to "almost double my fuel consumption" I'd carry out these 3 maintenance procedures
i) fill the interior with bricks
ii) wear a lead-lined right boot
iii) dirty-up the AAC
sorry! I couldn't resist - but fond of your thread all the same!
haha
that reminds me, i gotta clean my aac one of these days
hope its not too hard..
mate its not hard at all. go check out the DIY guide, takes 20 mins.
petern- i had great results with the liqui moly. i really didnt expect much from it, but i would highly recommend it to anyone, and for 20 bucks whats not to loose. i will now be adding it to my list of things to do when i service the car every 5000k's. i also find electrical cleaner works a treat for cleaning the AFM. adam
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
