hey all,
my car went through the pits today i have an r33 gts-t they picked up a few little things, bov, pod and a few others,
but also they got me for my battery in the boot.. im sure they come out factory with them there, said i needed to get a sealed box or something to put it in but just want to know if this is legal or just bullsh!t..
https://www.sau.com.au/forums/topic/278499-battery-in-boot/
what about if its a dry cell battery pretty sure they wouldnt comply all r33's if it wasnt legal...
cmon there must be heaps of other people who have had this trouble?
I've had this issue with my 32 when I transferred the battery to the boot.
It has to be as I stated above to comply with ADR's.
It doesn't matter if you use a dry cell or not as one day you may have to replace it with a standard lead acid battery.
https://www.sau.com.au/forums/topic/278499-battery-in-boot/#findComment-4705819
Did yours have teh little pipe thing that comes off the battery? That's what you need afaik (the pipe leads out of the boot... not sure)
https://www.sau.com.au/forums/topic/278499-battery-in-boot/#findComment-4705823
a bit off topic but has any1 put there battery in the boot of a r34??
if so what size battery...any issues??
sure have, its deka intimidator deep cycle. i think the size is what they class as a "34". as you can see i have a false floor to cover my LPG tank and amp's and it also locks the battery down at the same time.
regards
Chris
https://www.sau.com.au/forums/topic/278499-battery-in-boot/#findComment-4707943
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
