I cant believe this has happened the next day i put my new rims on..
getting on the M2 i accelerated put the foot down.. car looses power whilst gearing down.
no power at all
i can hear the turbo spooling but it's making a wierd noise instead of the familiar high pitch noise...
the noise sounds like a electrical fan thats on it's way out everytime the turbo kicks in...
So far i 've checked the codes on the car and it seems the Air Mass Senesor is faulity and also have another code on the Manifold Absolute pressure.
ive ordered a new AFM but people whom had turbo trouble in the past please shed some light to me..
Do u guys think it's new turbo time??
https://www.sau.com.au/forums/topic/279106-i-think-my-cars-ed/
  • Replies 108
hmmmm without seeing I think it may be
+1.
Does it just make a high pitched sound or is it a sort of "Lllllolololololololololololo" type sound when under "boost"?
Not only that, but we had another M35 turbo go last week, exhaust wheel sheared itself from the shaft... Rumour has it, that is rather common... Never heard of it happening myself :)
(Let me know how you go Jase. Hope the info helped.)
Current definite state of origin score;
VIC - 2
NSW - 2 *Danny's is not a definite.... :) ....yet*
Edited by iamhe77
VIC - 2
With stat's like that, it's confirmed the C34 is more reliable than the M35 and a much better car.
(let the fight begin) :)
Thats why i stuck to an RB stagea... coulda gone the volvo looking new one, but f**k that.
Whilst I don't want to take this thread off on a M35 v C34 tangent... I am wondering how long an RB's OE turbo would last at 12-15psi... 100,000km's? Doubt it. Not to mention the timing belt... Don't you wish you had a chain instead?
LOL
I suppose that is why you are selling it.
Must be real happy with your C34, ay?
Edited by iamhe77
Could be just on totally the wrong track here, but i have found with a manual car anyway, when you put power down get a whole lota noise and such but no power its clutch, not too sure how this works with an auto but could it be something there?
Hi Danny
I don't know if this any help to you but I have a spare turbo that I am renting (for lack of a better word), so you could get this rebuilt and then just do a straight swap on the turbo.
The change over cost will be $50, provided I am given a turbo with in tact housing on return.
Let me know if you are interested. Send me a PM.
Cheers
Andy
LOL
Danny - check your intake piping, you'll be pissed if you start pulling everything apart expecting a turbo fault & discover a loose hose clamp, or split pipe...
WRT to the RB OE turbo at 15psi - not very bloody long. But it's not designed to, whereas the M35's is (theoretically...)
Yes, I wish I had a chain :D I was brought up on the L/FJ series, and the double-row chains are a 'good thing'!
(don't get me started on the SR timing gear - the Nissan engineers were having an off-day when they designed that one)
This is rather common in the 'frog eye' WRX Subarus with the TD04, I know 3-4 WRX drivers who've had this happen, havn't heard of a NISSAN with the same issue though.
Simple, buy an NA M35 :D ALMOST as much go without the hair drier :P
Edited by chad bob
(let the fight begin) :P
And did you know it comes in manual, I have heard a few M35 drivers mention they wished there cars had a manual option :)
danny you ordered new parts??
mate i dont use my car mid-week mostly, if you need any bits to borrow i dont mind lending them to test your car. the turbo might be a little hard :P but AFM, MAP sensors etc
lemme know
rofl fighting and such..
i've been doing some crazy research atm
seems like GCG turbos do the highflow job
anywhere else in NSW?
Danny,
i've always got my stuff done at turbo logic in the gong.. never had a problem in the years i've been using him
(let the fight begin) :blink:
My s2 turbo died at less kms than my M35 has now. The M35 turbo is likely very similar to the one used in the s2 stageas. Either way they are both ceramic and suffer the same limitations. The M35 only runs ~11 psi out of the factory so to my mind the only danger occurs when increasing the boost by either a boost guage or altering pressure somewhere in the system (ie. free-er flowing exhaust).
Of course there are some that are just unlucky, but that happens to the s2's as well (happened to mine at stock boost).
We could always run 7-8psi boost on the M35, but then we'd have to put up with s2 performance :P (just teasing - i used to own one).
Other than this I've yet to see or hear of evidence of any model of stagea having any "weak points" reliability-wise.
*cough* power windows *cough*
I really need to get this swine flu looked at :blink:
I never heard of this being a common fault with M35's...is it?
After a quick search I found 1 thread regarding this - the button still worked but just not the AUTO part.
Sorry Danny, offtopic... :P
Hope you get it sorted...
Edited by pixel8r
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
