ok guys new arrival at 2:09pm at dandenong hospital Noah Albert Rowe decided to join the big world 6 weeks early mum is doing fine baby is in special care nursery due to being 6 weeks prem. baby weighed 2.92kgs jet black hair and very long fingers arms legs and feet. will post pics up soon
https://www.sau.com.au/forums/topic/279145-new-arrival/
congrats dooooood
my sister is a nurse in special care nursery in dande hospital. ill tell her to take extra specail care of future SAU member lol
who is ur sister, whats her name?? im goin to be in there every day till he is out. kylie comes home tomorrow but noah has to stay:(
https://www.sau.com.au/forums/topic/279145-new-arrival/#findComment-4716731
