  • Replies 79
Yeah i cant say this is a totally bad thing, i've just never checked how far from the deck a standard skyline is, whats the difference between standard ride height and 100mm??
I do agree in many extents, the amount of idiots i'm seen who join the "drop it and give it 20's" drives me nuts.
I'm just wondering what they mean by permission exactly, does this just mean get an engineers cert, or that they want paper work from the RTA before hand specifically allowing you to have the mod performed.
i thought lowering a car helped improve the handling of a car???
To a certain degree, yes. But there are those out there who go overboard.
I think what they are mainly concerned with is maintaining the geometry of the vehicle.
To stop the fully sic dropped wrx and vl im all for it.
as these punks go 2km over a speed hump and on an angle, like please if u werent such a "fully sic" racer u wouldnt need to drive 2km over a hump on an angle
to that aspect good, defect all these morons
soon we will see cops with tape measures approaching the car
heheheheh
Typical press release from politician who has absolutely no idea what he is talking about. Michael Daley quite obviously hasn't got a clue. A very confusing press release with conflicting wording and contradictory statements. We will just have to wait for the pubic service bureaucrats to sort out another mess created by their minister.
Cheers
Gary
Someone will need to tell this ignoramus that every used car is lower than a brand new car, it's called settling and it happens to every car. The older the car, the more k's the greater the settling. The Recognition Documents for cars that are lodged by their manufacturer with DOTARS (for ADR approval) shows their new height. So his ministerial limo needs approval because it's lower than its recognition document height. Arrest him he's a hoon. :)
Cheers
Gary
Cheers
Gary
Ever thought of entering politics SK??
5cm isnt much.....so if I load my work vehicle up and i get pulled up am I going to be fined for being a hoon...cause Im certainly not pulling 400L worth of diesel off the back of a ute so they can measure it with out a load etc.
And what about cars like a commodere Executive dealer fitted with FE2 or HSV spec suspention.
What a shit law!!!
Actually, Ando (s13deviat) was coming back from Wakie, had gtr rims and semi's and tools etc etc in the backl of his s13
now the car would have weight alot more, and lowered the car more because of the extra gear in the car. got pulled over because car was too low. Tried explaining that to the officerbecause of the extra gear it looks lower.
bit of a joke, so if your carrying things, or even towing, you'll be labled as a hoon because your car will look too low.
sydney kid for pm? :)
Those minitrucking types are in for a rude shock. I've been exposed to their culture before and some of the things they do to their suspension are horrific! Then again there are the smart ones that get their trucks engineered but still, taking leaves out of your springs can't be good.
Just saw this on another forum
Originally Posted by www.fordmods.com.au
I've just been on the phone to the RTA. Apparently this is the go
- There has been no official word (suprise suprise)
- The bloke I spoke to said that the paper has got it wrong
- At the moment they are looking at limiting how much a car can be raised, not lowered.
- Currently the existing 100mm ground clearance / 1/3 suspension travel is still in place
- Any changes would most likely affect any new installations i.e. anyone with changes done befoe August 1st would be ok
This is just what the bloke has told me.
haha this is stupid. so basically you can say the lowering was done before 1st of august and your in the clear?
Yup, and the cop who pulled you over will believe it........... Riiiiiiiiiight.
I agree, it's stupid.
by, "all modifications needing approval", does that mean everything including pods, mags, lowering, raising, exhaust???
I saw the paper today and the small article listed this aswell.
"any modification to a vehicle will now need engineer approval"
This is crazy. If its from August 1st, how can they prove you did it before Aug 1st?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
