Theres a guy selling these on Yahoo japan for only 3000 Yen which is about $40 but shipped with all importmonster fees etc it comes to about $140 :D
Has anyone seen these in australia anywhere? Or if anyone's contemplating ordering from importmonster soon, wouldn't mind paying $20 towards your shipping fees if you could include it in your package
https://www.sau.com.au/forums/topic/279931-r34-led-bootlid-brake-light/
hm looking on ebay and there are tons of brake leds in all sorts of shapes and sizes .. pretty cheap too. Might get one of them and just cannibalize it ..take out the board with the leds and stick under my lens :) Now just to find the right length one with 2 rows of leds..
Delta - i dun mind to do a group buy with ya for the first bootlid brake light. might be able to save that $140 fees to say $80-90 per person since i know a mate of mine who deals regularly in japan.
do u have a link ?
Howie - that led lights cost about $300 aud. so...........pffttt 300 for led lights ???
Denis, I can get something along the lines of this - These actually look like they will fit inside the reverse lens housing pretty well, will look like the one above when illuminated...these are 30 x 70mm I think.
I'd say these work out at about $30 each
For the bootlid 3 of these should fit - total 16 x 120mm - Works out about $25 total
cool I was just looking into doing a GB and it'd come to about $60 if I could get 10 interested people but if you can do it cheaper, even better :) Any ideas when you might be able to bring these in ? How hard would it be to connect them all together to fill the entire length of the light
I'm tempted to do a GB on these ones above anyway just cause they look so awesome :P Fark it I'll do a GB and see what happens if there's not enough interest you'll know it's a waste of time for you to bother with them too.
I'm starting to regret typing in 'r34 led' on the yahoo auctions ...
LED side indicators ..
LED front indicators ..
R34 Sedan LED tail lights (including the indicators / reverse lights)
I swear if someone did complete LED conversion then added in those sexy audi-style LEDs in the headlights .. it would look a totally different car - and sex on wheels.
I'm sure there are shops that specialize in bling like this but they'd charge you a ton to get all that done .. just do it yourself, one by one like I did :) Not entirely sure led blinkers (front/side) would look good. I mean they blink ..for a second, then they don't blink ..then blink again. Not like you could tell the difference between an LED and normal blinkers. I have the smoked nismo blinkers on the side/front and they look tops and do the job :)
Yeah, I have the non-smoked nismo indicators on the front/side on my R34. To be honest the side indicators didn't look as neat (only three LEDs, I reckon it would look quite stupid in the daytime). However, the front indicators were basically a big cluster of orange LEDs:
Sides:
Fronts:
You are right though - I'm not sure if you'd notice a difference. But if you're going to LED everything else ...
I'm contemplating grabbing ripping apart my tail lights and seeing how difficult it would be to do. A second-hand set of tail lights isn't that expensive to give me some piece of mind if i were to attack it anyway. One difficulty I have is that I wouldn't even be sure where I would source LEDs and some of the yahoo auction pages mention relays and other nonsense.
Wonder what 666DAN has to say ...
stock tail lights are def do-able as there's a guy in japan (yahoo auctions again) that sells nismo-lookalikes, basically stockies with leds inserted into them.
Having said that, I've just recently taken a look myself when I was replacing mine with the eastbear copies .. and the lens is glued on there with some sort of silicone + clips all around, so it'd be a bitch to remove. But maybe with some patience and a spare set to fall back to ..why not try. But then you still have to do the whole leds thing....arrrg. Might be cheaper just to sell the stockies and buy the ones from japan which came to about $600 delivered iirc.
But honestly ..the eastbear copies on ebay.com.au look tops too. I just painted my blinkers orange (as I don't like clear plastics) ..at first I wasn't so fond of the bling but it's grown on me and I could never go back.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
