hows this build coming along ?
Hi
The cars coming along very well, just finished getting all the sound deadening out and cut the rear parcel shelf and wall out, and cleaned all the imperfections out, it look very nice. Construction of the cage will begin very soon, still tossing up the idea to stitch weld the chassis and add more bracing in the cage.
As far as engine goes, ideas change like the wind, but most likely be running a JUN bottom end (maybe), also would anyone like to swap, I got a Brand New Trust T88 Mainfold with new 50mm Trust Waste Gate Never Been Used want to swap for a HKS T51R V-Band Manifold and a 60mm Wastegate.
I Have just order a heap of carbon goodies for the car to make it look the part:
-Carbon Grill
-Carbon Front Diffuser (Abflug Style)
-Carbon Rear Diffuser (Top Secret Style)
-Carbon Tomei Style Headlight intake.
More Pics coming soon.
Cheers
Benny
This is a very nice project.
Love to see some more pictures.
The only Achilles I can see in your setup is the gearbox. It will get you in the 9 but be very difficult to get into the 8 with it.
How fast has Mark and Paul done in this box?
Theo Woollett, got into the 8 with the ppg dog box, but it took him a very long time. His gearbox maintenance bill, if he was not sponsor, would have been very big too.
While you are still at the drawing board stage, it might be worthwhile to think about a sequential gearbox (OS88 or Hollinger). It will save you a lot of money and heart ache in the long run.
That was my 1st thought aswell
I didnt think there was much difference in HP rating between the 38gk and T62r
The 38gk is an 1100hp turbo and the HKS 1200hp
Either way I doubt either would be big enough to run 8's in a GTR
huh ??.... reece mcgregor used a T51R SPL to run 7's
althought this wasnt using radial tyres... "Dunlop SP Sport Dragway Special Tyres"
Hi Guys
Here's some quick update pic's, cars nearly finish the stitch/tac weld stage, rollcage commencing next week. Also new carbon parts should be arriving today or tommorow.
Cheers
Benny
Hi Guys
More pics of the carbon goodies that turned up today, i would like to give a big thanks to John at Rota Australia for his great Service and Help.
Ordering Soon:
-Carbon Boot
-Carbon Doors
-Carbon Prop Shaft
Cheers Benny
  • 1 month later...
  • 4 weeks later...
Hi Guys
Ordering Soon:
-Carbon Boot
-Carbon Doors
-Carbon Prop Shaft
Cheers Benny
Whered the diffusers come from?
  • 3 weeks later...
Quick Update,
The car is coming along great, our initial completion date was January, but you know how these things go delays, waiting for parts and have not had the time off to do anything. Anyway rollcage has been given to a professional welder, looks awesome will be stiff as a board. The Custom Jun Stroker kit arrived this week along with some Jun Hi-Step Cams, so engine will hopefully be done very soon (cant wait). The problem we have at the moment is the interior, we cant decide whether to carbon overlay everything or flock it. I wanna go with carbon, it will just take ages to do thats all.
Possible Parts Update list:
-Wilwood Front Brakes & R33 GTR Brembo Rears
-Full Ikeya Formula Suspension setup.
-6 Boost Manifold & HKS 60mm Wastegate
-Whiteline Swaybars
-Plus much more
P.S needs coilovers for car for drag setup HKS Drag Coilovers would be nice, if anyone has any for sale, also chasing a 3.5" or 4" titanium or stainless catback exhaust.
Also will someone please take this Trust Manifold and Wastegate of my hands!!!!!
http://www.skylinesaustralia.com/forums/Tr...12#entry4911612
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
