  • 4 weeks later...
For those that are curious, this months edition of PI (Performance Imports) is in stores now if you want to see some awesome pic's of it, cheersthumbsup.gif
Just picked up my copy :) I will be flicking through it soon :) You have made me want Bride seats now :)
Hi Guys,
Our Car is on the Front cover of HPI Mag this Month, Issue No. 142, Very good article from the guys at HPI.
Just an update on the car, Have been building a 6mm thick Scatter shield around the Bell housing on the GTR as any GTR owner would know there is very minimal room around the top of the gearbox once its in the car. Somehow we persisted for weeks to make this Guard. Just waiting for a Strain guage to turn up, and than we should be putting the engine back in the car over the christmas period. The Car will be going back to Mark Jacobson at Godzilla Motorsport for a check up and retune the car at 35psi around the end of Jan-Feb.
Here is the REG 4.9.7 out of the 2011/2012 ANDRA rulebook:- The use of a properly constructed steel, aluminium with steel or titanium lining, titanium bell-housing is mandatory for clutch equipped vehicles in top fuel, funny car, top alcohol, top doorslammer, Pro stock, and competition eliminator. All other clutch equipped cars running quicker than 11.00 (1/4 mile) / 7.00 seconds (1/8 mile) are required to use a steel, aluminium with steel or titanium lining, or titanium bell-housing or shield. Bellhousings certified to SFI6.1, 6.2, 6.3, will be acceptable providing the SFI spec matches the clutch assembly used. A totally Enclosing 360 Degree, one-piece bell housing must be formed or fabricated entirely from 6mm (1/4 inch) steel plate and attached directly to the rear of the engine. Where used, Flywheel shields must be constructed so they completely surround the clutch failure. The shield should be constructed from 6mm (1/4 inch) steel plate, and extend forward to a point at least 25mm (1 Inch) ahead of the flywheel, and 25mm (1inch) to the rear of the clutch and pressure plate. Shields must not be bolted to the bell housing and should attach securely to the frame/chassis. all the shields or bellhousings must be removed from the vehicle for checking during the technical inspection. An engine support strap made of steel or aircraft cable (chain not accepted) capable of supporting the rear of the engine in case of bell housing failure is required on all cars, unless it is evident that the headers or frame rails will prevent the engine from dropping.
Will upload some photos of the Scatter shield next week, it also added about 15KG of weight to the car,
I'm surprised that after 20odd years no-one has made an SFI approved bell housing for these yet.
Either way I am so glad my car is Auto because mine has even less room that the skyline around the bell housing...not that It will be running quicker than 11.00 for a while
Hi Guys,
Got some gear for sale if anyone is interested. All the prices are only for the items, postage is extra.
This is a 12/24volt Pre Lube pump with -12 inlet and outlet, can pump up to 60PSI. We used it as a safety backup if we lost our dry sump pump belt we had the pump kick in off a pressure switch. These pumps are $600 brand new and this one was used once, and we changed our setup due to new ANDRA rules. Im asking $400
Morroso Breather Tank with -12 Male JIC fitting. $100
Proflow -12 Oil or fuel 100micron screen. was used in the prelube oil setup. $75
Peterson -16 Oil screen 100micron, Rocket Ind wants $170 for a new one. This is used once aswell im asking $100
3 Gallon Peterson Dry sump tank, Dual Scavange inlet, Added extra -12 Male JIC at the bottem welded in. In Very good condition, Rocket industries is asking $815 with the two clamps.
Im asking $600.
HKS turbo shield $50
Stillway Shifter used once, reason for selling it is a short shifter and is to hard to change gear with a straight cut dog box, but works really good in its concept. Would be ideal in a streeter/drag car. The going price is $600 it took quite a few months to source this item.
Custom made fitting for the dry sump tank, -12 O ring port to -16 female JIC for the Screen return. $50
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
