  • Replies 78
Posted Images
Plenty of parking in surrounding streets just be aware that the son of rajab will not look fondly upon you if u try n park in the church across the road :D
Seriously thou they shut the boom gate early so i advise against it!!
OH SHIZEN!@!!@@!@
I totally forgot, I was thinking all day that I needed to leave work early for some reason..
Sorry all was looking forward to this, Thanks to Matboy for offering a lift there shame I forgot to call haha.
See you all at texi (lets see if I forget that too), i'll be the completely lost bastard not knowing whats going on :P
Well it was a good night sitting around talking crap,,,everybody laughing at my gammy hand,,,thanks everybody. We waited and waited for Steve to arrive with the much awaited track layout but alas he could not be with us.
It didn't really matter in the end because we all had a good time and thats what matters.
So after spending so much time getting there and only getting to see 2 tracks I thought I should post 1 of them,,,only because not everybody who was present got to see. So now everybody has a look. memorize it!!!.
Neil.
Pints of Stella be all sorts of better when they're served in a glass with a handle.
Good to catch up again after 3 yrs. Next time I'll wear a name tag for ando's sake :P
Hahahaha, it was Ben, right? One syllable, just like And, Nick, Neil, Dunc, Kel, Matt, etc... :)
Was a good night!
yeah but that's completely normal for me... usually sleep in a lot longer though lol
Thanks to everyone who came along, was a good night!
Hope you made it home ok Cass!!!
Bahaha, of course I made it home ok :(
I cheated and got a cab from Roseville :P
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
