Right.
So I got a bit sick of looking at that damn open airbox in my M35, no doubt sucking in warm air from the engine bay and I refuse to shell out $180 to Nissan for a Powerduct.
I decided to see how a secondary CAI would go on with a closed up airbox compared with the open airbox panel and stock air intake I was running.
While I was at it, I decided that enough was enough with the "sucked in" opening to the OE intake funnel.
As you can see below, the airbox panel is removed (duh!) and the right side of the air funnel has almost been sucked closed.
I was toying with the idea of an aluminium airbox with pod for some time, but decided to go this route first as it would cost very little if there was no improvement.
First up, the factory air intake funnel.
I found these some plastic wall lugs in my tool box (similar to THESE).
Drilled 3 holes in the bottom of the intake funnel, painted the lugs black and gently screwed a screw into each of them from underneath.
It stretched open the right side of the funnel quite a bit, yet the bonnet causes no damage to it at all.
end result looks like this
Next, I cut out the inside of the "drain hole area" of the bottom of the airbox (obvious when you look) and stuffed one end of 40mm flexible pond hose into it.
I went with 40mm as it was all I had lying around, but you can buy it by the metre from any Reece Irrigation store (probably other Irrigation or Pool shop would stock it too).
I used pond hose as the inside wall is quite flat and very slippery.
I bought an 80/50mm DWV reducer from Reece (or Bunnings or Mitre10... whatever) for a couple of bux, sprayed it with a matt black primer so it dried faster and stuffed the other end of the hose into the 50mm end to make the funnel.
I then just used a large cable-tie on one of the rear holes in the reo bar to hold it in position nice and tightly.
This is all you can see from the outside
Surprisingly, it has made a HUUUUGE difference. Car feels a lot more solid and I have no hesitation accellerating a bit harder now (no stupid WWWwwwo sound. Some of you M35 guys know what I mean). Top end of the rev range is fine as well.
If I put my hand in front of the funnel, I can feel the air getting gently sucked in when the car is idling. Can only be a good thing.
Takes about 45 mins all up if you let the primer dry. Far too easy.
It is a quick, easy mod that is quite beneficial, it would seem. A lot cheaper than a Powerduct as well.
Anyway, there you go!
Edited by iamhe77
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-4740653
Very nice Cam, I love the way you spread the standard intake apart.
How big can you go on the pipe?
LOL... I have heard that before :O:rofl:
The tube is 40mm, but there is a ton of room there.
I will probably be looking at 50mm or 65mm pond hose over the weekend, whichever fits on the outside of the airbox inlet so I can clamp it.
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-4741793
Don't forget Cam, for an extra $15 you can make your own Power Duct with not hot air from the motor getting in.
Looks good what you have done.
$15!!! Who do you think I am? Paul Allen?? Jeez man...
Have thought about the powerduct or making one of my own, as you did, but never really got around to doing it (too lazy).
Will be considered this weekend. Doubt it will end up as tidy as yours though mate.
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-4741804
How does this affect low-end performance? Some people have mentioned that the powerduct actually loses a little low-end performance (but has gains at the top end). I'm a little hesitant to experiment with opening that panel on the airbox for this reason.
Interested to know what results you have now with this method...I would've thought more air would mean more response all the way through but feedback from people who have installed the powerduct seem to indicate otherwise. Is it any different with opening the main intake more?
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-4741806
Maybe have lost a tiny, tiny bit of free revving over 5000rpm. When I had the airbox panel off, the car revved up to redline effortlessly.
Now, if you concentrate on it, you can tell it takes a touch longer to reach redline... but yes, it does feel a bit stronger (but much more "together") in up to 5k.
hmm, will see if a larger diameter tube will make a difference above 5k. If not, Imay have to make an "Andy Powerduct" this weekend and see if I can have the best of both worlds.
Edited by iamhe77
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-4741834
i might remove that scoop completely and duct in some more from the front using that intake to the airbox. and then also use your mod too. cant help opening it up some more!
Dunno how much more air you would get in via a tube than the funnel gets into the airbox.
You could try 76mm flexible intake tubing, but you still have to avoid the engine fan/fan shroud when looping it back the to airbox.
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-4741848
  • 1 month later...
Bit late with this, but I changed the 40mm tube for 50mm of the same tube.
No noticeable difference in performance... but a definite difference in install effort!
THIS is the pond hose that I used due to the smooth slippery inner wall (thus less drag/turbulence).
Well, so say it put up a fight is an understatement!
Firstly it was clamped to the outside of the connecting point on the bottom of the airbox (after some shaving), and then clamped to the outside of the CAI funnel, which was fine.
Finding the optimum length of 50mm hose which would allow me to place the funnel in the gab in the front bar WITHOUT popping the damn airbox out of it's mounts was another thing altogether.
Even when I cut the hose to the right length, it had to be wrestled into place.
Still pushes against the front bar!
My recommendation is to stick with 40mm if you are using that pond hose. No performance gains from 40mm to 50mm.
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-4816014
I just pulled the cover off the airbox and removed the bonnet seal directly in fornt of the airbox, then I wound up the bonnet stopper just a bit.
With the cold air rushing in there at speed there shouldn't be any warm air getting in.
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-4820506
  • 4 years later...
So I thought I would have a bit of a play with my stock air box and intake to see how much cool air I could get in.
Liked the idea of opening up the snorkel but I just used one support on each side and a bit longer to open it up more.
Left the cover on where the "powerduct" would go for that stealth look.
Then I took to the inside of the air box with a die grinder to get rid of all the ribs and smooth it out for better flow (maybe).
Also removed that resonator chamber that just unclips and covered the opening with some aluminium sheet and some self adhesive foam.
Cut a 76mm (3") hole in the bottom.
Got some 76mm flexible tube from Clarke Rubber and just managed to squeeze it down to the lower bumper.
It wedges in against the bumper quite well (didn't use any cable ties) and is far enough back that it hopefully won't catch too much water or bugs.
Finally, I removed that hard plastic tube from the intake pipe and got a Turbosmart 38mm BOV plug which is actually a bit small and nearly fell through!
I have since found a 44mm blanking plug from eBay and it fits much better (put the old hose clamp back on too).
Results? Not so much down low but definite improvement in mid to high revs. Lower rpm (50ish) at idle too but not to the point where it's going to stall.
Loving the increase in induction noise/turbo whistle (sounds like an F1 car, small capacity V6 turbo, screeching tyres, sideways action, I think the new F1 cars are all good!)
Now for an exhaust to make use of all this extra air!
  • Like 5
https://www.sau.com.au/forums/topic/281215-~10-intake-mod/#findComment-7382490
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
