  • Replies 187
Posted Images
Zennon, thats an awesome picture! Bit dark though, but thats just my opinion.
Yeah think you're right actually - it looked fine at home but then when I saw it on my work pc is was like :)
(then realised it was because I had played with my gamma and brightness at home so i can see the bloody counter strike campers :) )
OT
what do you think of the innov8? im tossing up that or an ultra touch.. my nokia N85 is rubbish never again!
the innov8 was barely sold here. Mine was bought overseas from ebay. Very hard to find one here and hence running overseas firmware (couldnt find australian firmaware) It doesnt affect the functionality of the phone but.
Depends what you are after on a phone.
The innov8 has wifi and runs on symbian OS (same operating system as the new gen nokia's, so there are many applications you can run. After you crack the phone there are a lot of apps to download. Ive got about 3 different GPS programs and 2 different office suite apps) also has 8gb or 16gb internal memory.
Also the middle button on the innov8 is infra-red sensor, so you slide your thumb over it to move the cursor when browsing websites etc. Think of it as a mini touch pad on laptops. Although its much more sensitive as its a small pad.
Quickly reading about the ultra touch, they are touch screen but dont have wifi or big internal memory. however they are very small phone.
sweet ill go grab a 16gb one then, my only prob with internal mem phones is if you drop it in water you cant easily remove the mem card to download your data, just means more frequent backuping....
The i8510 does have a memory card slot, so you can get a 8gb internal and then buy a 8gb card if you want.
first attempt at some panning shots.. lots of practice needed... and a decent lens for it, was using the 50mm for these ones. I think.. might have been the stock lens too..
what noticable difference does the lens make when panning?
yeah I know you can do it with any lens, but with the 50mm it was hard to get the whole car in focus, it usually focused on the rear or the door or the front but not the whole thing
don't use it wide open then?
he was using f22.
i dont think you did to bad considering they were taken at 1/40th of a second. maybe start at 100th and work your way down from there. although im no pro so take that with a grain of salt.
Edited by Jay019
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
