I picked these up for my 33 - still on the way from japan at the moment... what do you guys think?
Also, it uses the inner brake light as in indicator i think - is that illegal?
anyway - thought it would be something a bit different, and they are full carbon, so will match in with my black paint.
dave
https://www.sau.com.au/forums/topic/28219-what-do-you-think-of-these/
