Hey all,
I searched but had no luck as I cant get it to work.
Anyway I have a 4 door r33. It has a powerfc with hand controller, Front mount, Greddy style inlet manifold, stock turbo running 11psi, full exhaust blah blah blah. A while ago my engine fan decided to explode through my radiator :/ So I went out and got myself an alloy radiator with a thermo on a temperature switch.
I am after a temperature at which I should set the thermo to kick in and start cooling. Half way on the stock temp gauge is anywhere from 75 up to 90 degrees so I can't set it by lookng at that.
Any help would be appreciated...
https://www.sau.com.au/forums/topic/282367-rb25det-running-temperature/
You can set the thermo to come on as high as 90, even 95.
The idea of a thermo is to only react to extreme coolant temperatures. Ordinarily, as the car moves along there is sufficient airflow through the radiator core to control the coolant temp. Even after idling for several minutes - like in stop-start traffic - when you get moving again, the air movement will cool the coolant back to the thermostatted temp.
i dont have a fan
havent had one since the FMIC went on
no issues with overheating etc
the radiator was replaced with a better core though (original was leaking)
my temps are normally too low, under 80 is common
80deg is ideal water temp, with default settings, the PFC (and stock ecu) will retard timing and richen up until it hits 80deg
its a minor correct, but its still a correction. i could never get my car to 80deg so i changed the water temp to be 0 0 and 50deg
so from 50deg onwards theres no correct. its covered in the PFC FAQ in my sig
i dont have a fan
Do you run glycol in your coolant/water? Adding/increasing the gylcol concentration would make the system less efficient and should nudge up the temps. Also means you don't have to worry about boil until even higher temps.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
