I love what you've done with the car Cara ..that's a really cool unique look but not many can pull it off unless advertising their business because then it usually looks cheezy :( Oh and what sort of power did you get on the dyno?
https://www.sau.com.au/forums/topic/282869-neon-lights/#findComment-4761094
Hmm,
Exterior = No No on Street, unless parked, advertising or trying to grab attention to advertise. On show cars IN a show is alright.
Interior, I guess its ok just to light up the footwells and thats the max I would do, none of those " 6x9 speaker neons that strobe to your bass" crap.
Just my opinion.
MRXTCZ
https://www.sau.com.au/forums/topic/282869-neon-lights/#findComment-4761161
I love what you've done with the car Cara ..that's a really cool unique look but not many can pull it off unless advertising their business because then it usually looks cheezy :) Oh and what sort of power did you get on the dyno?
thanks dude, those were last years graphics :) but i really like that pic of her on the dybo :D
was having issues at the time with the girl so i think she made like 110 or something, couldnt work out what was going on :( so she didnt do her best at all :(
https://www.sau.com.au/forums/topic/282869-neon-lights/#findComment-4761958
Neons are old hat
I thought the kids are all into led strips these days, saw some the other day on a burgundy civic sedan all I could do was shake my head
I laughed in disgust when I first saw them on Audis, at least bmw's angel eyes are somewhat respectable, still a wank factor
the audi led strip to me is just a one-up to bmw that wasn't well thought out
https://www.sau.com.au/forums/topic/282869-neon-lights/#findComment-4762563
this is what my r34 used to look like with interior neons. dont get shiny reflective floor matts as they will light up your whole interior. its good and bad if you have dark tint. cops can see inside and wont be all its too dark pull him over. bad thing is when its too dark outside you cant see as the reflection of the neons on the inside on the window will make it difficult to see unless you have your window down.
https://www.sau.com.au/forums/topic/282869-neon-lights/#findComment-4762820
thanks dude, those were last years graphics :D but i really like that pic of her on the dybo ;)
If you'd switched the neons off you would have made an extra 90kw :) te he he he
https://www.sau.com.au/forums/topic/282869-neon-lights/#findComment-4763098
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
