Anyone Wrecking An M35 Or Importing Parts?
Hi everybody,
A while ago I took out one of my mirrors on a pole I didn't see, and I am chasing the left hand wing mirror cover to replace my damaged one. I don't need the motors, glass or light, just the outer cover. Nissan will not sell me just the outer cover and they want $560 + GST for the entire mirror. Can anyone help?
Thanks very much,
Brendan Diss
yup, i can.
ill have a pair of silver mirrors complete and working in about 2 weeks if you can wait that long? id probably sell you a whole one for $100 + shipping. id love to part it up, but ive done that before and still have bits of an S13 mirror at home from 10 years ago :(
OR, get a pair of mirror covers with indicators from IM. set you back a bit more, but they look really good!
also, i V35 mirrors are the same and will fit!
feel free to PM me if you like.
+1 on finding a wreck.
I may need a passenger side rear lower suspension arm (what the bottom of the damper is bolted to)
I was actually just after the bush, but it comes as an "all-in-one" unit.
*sigh* As you can see from Parts Master at the bottom of the image, it is just another part that is specific to the M35
Any wrecks around?
I have not yet contact Nissan requesting a price (my wallet shudders each and every time!).
Edited by iamhe77
they cant push the bush out?? aftermarket??
i rekon there will be a generic sized one that will fit, or something from a V35/Z33. nissan wouldnt change all that much, it would cost too much to manufacture a small volume for M35s (then again there are a shit load of them around in japan im told)
is this dew to that creaking sound you hear with the m35 while going up driveways etc?
i've also got a bad vibration occasionally on breaking. it doesnt happen all the time so i can cancel out brake rotors
Nah, it is because the bolt is seized in the lower shock mount bush (the nut can be taken off, but the bolt will not come out).
I don't think it has anything to do with the creaking, I would put that down to the front shocks.
I had my Nismo suspension (with the exception of LHR damper) installed and the creaks have completely disappeared.
yeah the tein's sometimes creak apparently? i'm not entirely sure. i thought maybe it was a sway bar still waiting on the Gb to happen for them tho..
must try find this shudder, scary when driving on the snowy roads and it does this.
Is it when you are at less than ~15kph? In snow mode??
Mine sometimes did this when reversing, but I have replicated it in the above conditions.
Get a transmission service... with either Nissan's Matic J AND their transmission additive satchel, or another fully synthetic, high quality fluid (such as Redline, Motul etc).
Should clear it up.
Edited by iamhe77
nar its defiantly got something to do with the steering/suspension arms/bushes etc..
in normal driving conditions. but only happens every now and then. can be cold, can be hot can be as soon as i get in the car, can be after a while.
on the topic now on tranny.. transmax z good to put in? and what was in this satchel?
The V35 & 350Z manuals (same auto trans as M35 stagea) say over and over to only use Nissan Matic J fluid. It says other fluids may deteriorate components over time...
I realise nissan aren't going to recommend other brands though...
I recently had my gearbox serviced, and the workshop used the Nissan Matic J because its all they had (not that there's anything wrong with it - I'd say its up there with anything else), but apparently Castrol do a Transmax E which would've been the one to use (according to the workshop). Dont quote me though.
Edited by pixel8r
well i think nissan say use matic j in the getrag for 34 also.. which i have in my 32..
but i was told transmax z was the best oil for the job. does both transfer and manual gearcase..
i just have some at home so was considering using it in the stagea..
I... with either Nissan's Matic J AND their transmission additive satchel ....
does anyone know about this satchel? the nissan dealer i went to told me i was stupid for suggesting that. and that nissan dont do that, it must be some aftermarket thing that a dealer put in for the customer......
Dunno what is in it, but all new auto Nissan's have it put into their transmissions.
Anyone else is not supposed to have it included in a service, it was just that the guys wanted to put it in when they serviced my trans last year.
I would imagine it is a combination of synthetic additives.
Certainly made a difference in mine!
They did tell me that t was from some company in the US and was designed specifically for Nissan for Nissan transmissions.
For some reason, it can be had for $30 if your dealership is friendly towards we "fringe dwellers" with our "underworld-roaming" cars.
out of interest i just looked this up.
http://www.tds.castrol.com.au/pdf%5C9070_T...828_2008_12.pdf
its specifically for japanese built transmissions and the pdf also says it is an alternative to nissan matic j.
The transmax z is probably fine too, but from the sounds of it this one is better? dunno.
 Share
