whats similar is that they are auto stags with highflows....... its all the same basic principles / theories.
S1, S2, M35, all stags with the varied stagea features, auto boxes are auto boxes, and high flows are highflows. again a variety in types..... :)
May be the same principles, but... auto boxes are not all the same. The clutch packs in my box are just too small for the power I want to run. Unless you know of a manual that fits easy, I have no choice but to limit the torque output.
I installed the turbo today, also stuck heat shield around the turbo on the firewall as im not running the rear heat shield. Gearbox doesnt look like its going to be assembled untill next week, as the custom clutch parts havent been manufactured yet. ;)
  • Replies 68
look into the 34 getrag.. seriously. or a 33,32 gtr box in general..
from the brief moment i was under my car i'd say it would have to fit.
a custom bell housing maybe, drive shaft, and prop shaft and bobs your uncleeeeeee...
Must people seem to stick with the ball bearing cores when high-flowing, as some have the opinion that moving from ball bearing to bush bearing is a downgrade even if it is high-flowed.
I'd be interested to hear how you find the bush bearing though, just make sure you take good care of it and use a turbo timer or give it a few minutes to idle before turning the engine off etc.
Once I get the ecu remap out of the way and know they can tune the M35 I'll be sending a turbo off to GCG for a ball bearing high-flow. (can't wait!)
Not really necessary Stephen.
All you have to do is take it easy for the last block on the way to your destination.
Not only will it allow the turbo to cool down, but also the transmission, diff etc, which all need to cool as well.
You don't need to worry about the negatives that a TT brings.
Should be fine. If you see how the ball bearing units work you wont be as impressed, much the same as an old bike hub.
I would have gone with gcg if they had been more forward with information.
The car is back on the road after the tune. It managed 200 at the wheels at 14 psi, which is quite respectable I think.
The turbine housing still seems to be the limiting factor and is the hardest part to change so I think that will end the power gains for now. The injectors, pump and regulator would also need changing if any more fuel was required.
Im very happy with the Kewish Automotive rebuild on the gearbox. Shifting is quick and firm at all power levels without any clunking at all, highly recommended.
And I have some mates coming around tomorrow to help me fit the BC coilovers. Hopefully that will sort the handling out too.
Pretty sure Nissan have been using JATCO boxes in Skylines/Stageas since S3 R31's
Try the late 1960's - the 1969-built LHD 240Z had the 3N71A, the 3N71B/4N71B was used from 1970 through to 1988(ish) in a number of Japanese makes and then the RE401-series took over until the end of the RB. I'm sure the current model is a JATCO too!
PS good power Scott - considering flexible engine management is still a bit of a headache.
:rolleyes:
200 killa wasps at 14psi....good result considering I was at 17psi to get 199.99kw's!.......must be the intercooler and wheel size making the difference.
Are you using the standard boost controller or an aftermarket one?
Edited by Jetwreck
3" FMIC piping = less pressure with higher flow
Congrats on powahhh, bloody respectable I'd say. Interested to hear your thoughts on the BC coilovers too.
Cheers, Dale
BC is not buddy club
they are different brand
although i was told that it's the same factroy (not 100% on this)
Buddclub dont have anything for the nm35's yet
ahhh got ya, i assumed buddy club :D
yeah a few brands steer clear of NM35s for some reason......
ASS | U | ME
(mainly because I assumed they were BuddyClub as well) :yes:
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
