Haha yess its only a photoshop job so it is still is a "4x4" LOL
As for suspension, I am leaning towards getting some king/tein springs with some sway bars on the stock shocks....however i might go the bilstein shocks with tein springs and swaybars....and yes i still got coilovers in mind but its being used as a daily so i dont think it is suggested.
check out D2 suspension, their even an aussie company, i got a set of 4 for 600$ NZ brand new cos they were clearing old stock, should have retailed for around 1500, can adjust dampening, ride hight and spring stiffness, coil overs arnt bad for a daily, mine is, and i drive on some crap roads sometimes, just need to learn where the bumps are and slow down when needed, which is better for your car anyways then just letting soft suspension take the pounding
I went onto JustJap and I can get a set of D2 and BC coilovers for like $1200. If I went for just the springs+shock setup im paying $1750 brand new. Still sourcing around for my best deal, so far I have:
Bilstein Shocks: $1350
King Springs: $400
D2 Coilovers: $1300
BC Coilovers: $1200
Maybe some links to other stuff could help and some more opinions. I also don't mind getting a good quality second hand pair if anyone has upgraded there suspension and wanting to sell there old setup.
As much as I hate King springs, I'd probably be going those and Bilsteins over cheap coilovers. Even if mine were to die, I'd get some slightly lower than stock spring and Bilstein monotube shocks. Cheap coilovers aren't really worth it, I mean who adjusts their suspension on a regular basis?
the advantage of a good coilover is that even if you lower it as far as it goes you still have full travel. if you just use an off the shelf lowered spring with standard spec shocks you will only have a small amount of travel before it bottoms out. this both wears the shock out quicker and gives you a much rougher ride, which then puts more stress on things like engine mounts and pretty much everything else. some coilovers though just reduce the height by lowering where the spring sits on the shock. this is basically the same as using lowered springs. it results in the same reduced travel as lowered springs, but will still usually have more travel than just lowered springs before bottoming out.
you can tell how they lower it just by looking at them. if they simply have thread at the base of the spring and the mounting brackets are fixed then they reduce the travel. tein super streets are like this. if the mounts of coilover have a lock nut up against them then they lower the car by moving the mount and not the spring (the spring is still adjustable though). HKS hipermax D's are like this.
that said, a mate of mine just got a set of (i think) aus spec tein super streets in his 33 and he loves them. he was worried about coilovers being too rough, but he said that they are heaps better than his lowered springs on stock shocks, which were bottoming out.
totally agree with mad082... for once :D
I'm looking at getting a set of HSD HR coilovers soon, or Ksports, i think it'll be worth the $$, and in the long run will save you money... but then again i use my car for drifting and road use aswell.. so i need that extra element.
ive just got lowered king springs and kyb shocks in the 34
How much did that setup cost?
And yes, i think i am going to keep away from lowered springs on stock shocks...the things i have read have just turned me off that idea haha.
The Bilsteins are expensive for a reason. Because they work....Basically coilovers are better than shocks, a $5000 set of coilovers is going to be better than the Bilsteins with king springs, but a $1500 set of coilovers compares to the most basic cheao $600 set of springs and shocks you can find, probily Gabriel base model designs..........
Lots of the Chinese coilovers barley pass ADR certification if they pass at all. look into that.
My set up is KYB with 5zigen springs at rear and stock GTR at the front.
If i had Bilsteins all round id be very happy.
Got some new quotes today...king springs for 320 hehe and the tein springs for 450. The guy wouldn't give me the quotes for the shocks because he didn't know how the mounting was for the shocks, said he wanted to see if its got a fork or eye mounts...the front of the GTS4 is the eye mounts i am guessing with the rears fork?
ive only got stock shocks on the back......the havent died yet lol
i got the springs second hand for a friend, they are actually the minimum legal height here in SA so i cant be done for having my car too low :D
i have to admit when i got them put in it was a much firmer ride, but that was when i had the 18"s on ....now i got 19"s lol definetly can feel those lil bumps in the road a lot more lol
They are not an Aussie company, they are all made in china, they are exactly the same as G4 / K-Sport, only differnce is the colour
lol fair enough...well i think i gotta take mine down for a little drive to a workshop and talk to some people..also probably going to melbourne soon so i might get some quotes from there aswell..hopefully goes all good haha.
turk1, the GTS-4 DOESN'T have the fork mounts at the rear.
When you get quotes you have to ask.
GTR front shocks and springs
GTS-T rear shocks and springs
If you stick your head under the rear of the car you can see the eye mounts on the front and rear.
I can get king springs for about 275 and TEIN's 390
Try find a mate who works at a auto shop, will save you heaps. I can order from the cheapest suppliers and not have to pay postage and everything
It will save you about 400 overall
Really? Can you get your hands on the shocks aswell? PM if you want bro, cheers!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
