happened this morning ^
only realised it was there when I got out.
the looks I got as I cut laps around the uni carpark looking for a park were priceless :)
hahaha thats so bad but funny
kinda looks like its attracted to the S badge
  • Replies 115
Posted Images
its called the CM4. i got it from carmate. the quality of the bar was very very very good compared to my old one.......we have bash in the "lumpy" bits at the bottom of the reo bar and it will line up alot better :) cant wait for it to be painted and have the graphics put back on :D
you should read the thread about removing the yellow in headlights :)
lol yeh, they haven't been cleaned in a while so they are looking very yellow atm.
they come up okay, but the biggest issue is the stuff on the inside of the cover. :D
and cara i hope the front bar is going to sit further back than in those pics. the massive difference in the wheel arch area looks super dodgy. but then if it does sit back the headlights will sit out from it a bit and look dodgy.
my other question is, how small is the output (projected area) of your headlights? because the eyelids top and bottom look like they would dramatically reduce your vision at night, which, no offense, i find really really stupid. "hey i can't see shit at night, but at least i look cool during the day...."
yeah the bar will sit back more. there are a couple of "lumps" in the reo bar that have to be pushed in more so that the bar can sit better on it.
and believe it or not with the eyelids, they never actually reduced the vision at night, i tested them when i first got them, and yeah there isnt much difference at all
oh man that front bar looks like it was pinched off a HSV :D
sif replace smashed front bars EVAH, everyone knows you are fully D1 spec chokku dori when you are missing chunks!~
ahahahaha, and zip-ties add more killerwasps
the looks I got as I cut laps around the uni carpark looking for a park were priceless :P
LOL thats crazy mann, im just about to eat aswell hahahaha.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
