I have recently upgraded from a GT35r to a TO4Z, but the engine would not make any more power - just exhaust manifold backpressure...
RB30_Power_Run1.pdfFetching info...
This is plot of the GT35 run. the TO4Z run is basically the same but has about 500rpm more lag.
Exhaust manifold backpressure with
GT35 is 30psi
TO4Z is 42psi
Inlet pressure is 20psi.
Any ideas that might cause this backpressure ???
Is the flow through a RB25 head likey to be the problem?
Setup is
RB30 block - built
RB25DET head - kelford cams 272deg 9.35mm lift, valve springs to suit
Custom exhaust manifold, merge collector similar to 6boost
Tial 44mm wastegate
4" exhaust, not cat
2.5" plumbing to intercooler, 3" after intercooler, 125mm thick GTR cooler.
Vh45 throttle body 80-90mm?
Jun Style inlet plemum.
720cc injectors
Autronic ecu
Hoping to make mid 400's rwkw
https://www.sau.com.au/forums/topic/284058-power-problems/
Have you dropped the exhaust from the dump pipe back?
Have you measured boost before and after fmic?
Sounds like you have a restriction somewhere and i doubt it's the rb25head.
My mechanic has made 485rwkw using a built rb25det and a T04Z (C16 fuel)
My car has made 330rwkw using a built rb25/30 and a GT30R (GT3076R)
** EDIT: **
Looking at your graph, the power you're making isn't bad at all :P
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4776165
Yes I have dropped the dump pipe, but not when on the dyno.
I have droped a tennis ball through it to check for blocks - it came out the other side so it gotta be pretty good.
Boost pressure either side of the intercooler is pretty much the same.
Dyno numbers aside, the strange thing is it just wont make any more power, we added 3psi boost and 2deg more timing - it only made 10 more kw.!
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4776496
Yeah what are the turbine housing sizes of the outgoing 35 and the new T04z ?? Having a pressure ratio over 2:1 is why your power has stopped increasing. Without knowing turbine housing sizes id still say you just need the next turbine housing size up.
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4779051
Yeh it was me, i could write a book on the issues ive had.!
The GT35r setup first started off with 250rwkw, for all that are interested - some of the issues / things changed were:
*Spigit in the new cams was misaligned creating vibration in the CAS causing a large timing fluctuation.
*The unit in the ECU that heats the A/F ratio sensor was causing timing problems also.
*The boost controller electronics were faulty.
*The cam timing wasnt spot on.
Im sure there was much more that I have forgotten, during the process we changed the exhaust manifold, the wastegate position, and the A/R of the turbine housing, set a crank trigger to run timing. (none of this probally needed doing)
I still had fairly high backpressure, but the car was running good and making good power so i just went out and enjoyed it.
That is untill the craving for more caused me to change turbos - highlighting the flow problem.
GT35 - A/R 1.06
TO4Z - A/R 1.00
You can see the hole in the manifold collector where the pressure reading were taken.
The muffler is 4" straight through.
cheers rob
Edited by roba
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4779907
So you just pushed on when you knew you had problems last time? ugh... should have fixed it then, because now look :blush:
If you have backpressure in the maniold its only going to be coming from a few places.
Do you see boost climbing as if the gate is not venting enough?
It could be manifold
wastegate not passing enough air (due to manifold)
exhaust causing blockage (a tennis ball is not a test)
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4779917
Retarded timing can cause large increases in exhaust BP. Perhaps you still have a timing issues. Checked timing under load on a dyno ?? (keep your head out of the way of belts incase they let go !)
And a simple way to rule out the exhaust system giving trouble is to move the pressure sensing out of the runner and into the dump for a few runs, or hook a boost gauge to it for a couple of runs. Then you can definatley rule it out.
As R31Nismoid said, tennis ball isnt a good test. You need to see the actual pressure. And when your this deep with problems, don't leave anything to chance.
Gary
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4780935
Have checked timing on dyno, and after we converted to crank trigger it rock solid.
Its not the exhaust - it's 4" straight through. http://www.skylinesaustralia.com/forums/po...98-IMG-2942.jpg
My engine builder thinks it is the cams as the duration at 0.05" is 216 and 216 (intake & ex). Advertised duration is 272 with 9.35mm lift
I dont know much about this area - can someone confirm this maybe the issue?
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4789606
not a 100% sure, but i think advertised and what they are at .050" are never the same. I believe the standard measurement is always at .050" though.
check the cam card though to be certain!
Edited by r33_racer
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4789968
my car did this. i spent months and months chasing the problem. Cams are not too small, i am making 375rwkw with STOCK cams.
I think the issue is cam timing. Getting the cam timing right on a RB30 is quite tricky. I would first start by setting both cam gears to 0 and then tuning it and see what power it makes. Dont be suprised if the power sky rockets. on my RB30DET the car makes the most power with the ext cam gear set to 0.
Set them all back to stock and try again - report back with results
https://www.sau.com.au/forums/topic/284058-power-problems/#findComment-4793040
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
