3 month holiday
32 race car- came back blew the motor and like a good track car its just sitting down the side of the house growing spiders(its waiting for me to find some spare time to swap the engine out... work, drinking, baby stuff, wasting money on tow cars and the above engine built has tapped out my play money for the last few months)
hr31 gtr monstor- long motor is assembled, just waiting on getting the shell back to shlap the motor in an plumb it up
busy at work but i predict the race car will have it new engine installed in early march (post work being hectik)
roy buy the whole kit and flog the turbos off or use them on your car $1700 for the whole kit red nuts... also helps me pay for my haltek + tune
  • Replies 716
Posted Images
  • 3 weeks later...
Top work on the sump, I have been keeping an eye on his fabrication thread lately.
Just out of interest does he install his own style of baffles into the sumps or does he make them to suit aftermarket styled ones like the Mines or Tomei baffle systems?
Getting a little closer to building the 26 in my GTR and I am pretty interested in getting a similar sump done up for it
Cheers Marty
21 psi= ic pipes flying off and the old rb26 chestnut of popping the dipstick out
at first i though i lost a turbo.. but was just an ic pipe flying off. kept doing it even at 15psi so i packed up
getting rid of the just china hoses and going something tougher and will be back out with about 17psi to keep things happy (eg longer lasting)
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
