  • Replies 716
Posted Images
  • 4 months later...
This bucket has been siting out the front of my house for a while
Engine and turbo were sold
I have a shitload of parts in my Shed to slap into it, i just have to find time... Who would have though a child would limit your pay time
Parts that are in the shed and need slapping i
Stock 26 with metal head gasket
Front and rear os diffs
Nismo suspension arms front and rear
Adjustable camber arms
Polka 997 gt3 brakes
Castor rods
4.4:1 diff gears
4 inch ti exhaust
New wiring loom
Plans are run it at low power say 250rwkw and buy some nice rubber for t so it's reliable and Doesn't eat engines
  • 5 weeks later...
yea sadly ive decied to upgrade to a newer model gtr (33 or 34, most likely r33 as they are cheap as piss and r34's are massivly overpriced)
lower power, reliable so jenna and i can hit the track and just lap it ( current record is 170 laps in a day)
need a low maintenance car that i can just take out... turns out having the little one has sapped my joy of late nights working on the car and replacing engines
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
