Who got lots of work done while SAU was down ?
I did ! he he he
You should check out some of the threads in the other states section: Some very funny stuff
WA lost 400 pages of their whoretown thread - all in three days !
I like this by Warderst :
"I'm now a dribbling mess.
My medical bills are going straight to the SAU admins.
Thats 15 hours of therapy @ 55 p/h inc. gst= $825
Prescriptions for:
Lithium = $85
Zanax = $67
Percodan = $78
Temazapam = $43
Nurofen = $10.45
Not to mention all the calls I made to phone sex lines because I was stressed.
135 calls = $1549.35
5 visits to The Boardroom
5 x 2 hours at $350 p/h = $3500. Hang on, I do that each week anyway so I won't bill SAU for that
Lets see, that all comes to:
$2657.78 in Therapy. anti-depressant phamaceuticals and phone relief.
I'll happily take a cheque."
Where's Mayor Rudi Juliani when you need him ????
We can rebuild - We can make up for lost time !
So guys - what did you do when SAU was down ???
I'm just thinking about what will happen to some of the juicier threads that built up a lot of momentum over the last month . Will the mometum be lost or will the thread continue ? What do you think ?
As an example - My plenum results thread - all the recent info there is gone and discussion around it too - And there was some intereting stuff in there - I wonder if the same people will make the same comments back in the thread for others to enjoy in the future ??
Is suppose it will come down to the invididual to make it happen !
Stared blankly at my screen for hours on end - hitting refresh every 2 minutes in the vein hope that my forum lifeline would spring back to life.
ditto x 100000000000000
Adrian
I got addicted to reading this confessions site. I had previously looked at it and gotten over it, but then with SAU down I got too bored with nothing to do at work so I went back there.
At home, I got a lot more online gaming done :) I still went out no more or less than before, but whenever we did leave there was never any "hang on a sec, just gotta check my email" before we left, like usual.
lol, it will be "Welcome to Yesterday" :)
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
