Hi Prank
Know you are really busy with all this stuff at the the mo but HELP--
My usual login is blackdoggette - I can login ok and forum recognises I am online but as soon as I try to post, look at my profile or PM someone I can an error back (largish) that looks like I am not activated or something???
I joined about a month ago so am assuming with the recent forum death and re-birth that something is very amiss...
I sent you an email (of course I tried to PM and post but couldn't) very early today and hadn't heard anything so I joined forum again tonight using this username - Nissy
Help
---many many thanks
when it gets all sorted I will let you know and you can delete this account
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-595091
  • Replies 64
Hey just a fiew things, you probably know them all already.
1. in the change avatar option there is only the option to delete.
2. Webmail isn't working? Outlook works fine tho :rofl:
3. FTP to upload to webspace doesn't work? (ERROR: Windows can not access the folder, make sure you typed the file name correctly and have permission to access the folder.) in the pm you sent me you said
*Server; ftp.skylinesaustralia.com
*Location; http://www.skylinesaustralia.com/members/endorean/
thats not my username perhaps its pointing to someone elses webspace?
That is All :D
Thankyou Very Very much :)
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-598140
PranK,
It appears that you can edit other people's gallery images, manipulate them and add text. Obviously there is a very bored/sad soul out there which finds it funny. Don't know what the login area for it is for? Username and P/W don't work there??
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-600010
You would have to be pretty bored. Would be good if the only people who could edit your photos, are you and the moderators. Still wouldn't stop bored souls posting rubbish though and as the gallery grows, it may become a problem keeping track of it all. It will be a damn shame if stronger restrictions then that have to be put in place.
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-600414
FTP should now be working.
Sing out if theres problems.
C:>ftp skylinesaustralia.com
Connected to skylinesaustralia.com.
220 SAU FTP
User (skylinesaustralia.com:(none)): [email protected]
331 Password required for [email protected].
Password:
230 User [email protected] logged in.
ftp> put boot.ini
200 PORT command successful
150 Opening ASCII mode data connection for boot.ini
226 Transfer complete.
ftp: 192 bytes sent in 0.00Seconds 192000.00Kbytes/sec.
ftp> ls
150 Opening ASCII mode data connection for file list
boot.ini
ftp: 10 bytes received in 0.00Seconds 10000.00Kbytes/sec.
ftp>
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-602587
dude all links that don't point to forums.skylinesaustralia.com/forums don't work. I think it used to be either forums.skylinesaustralia.com OR www.skylinesaustralia.com/forums.
Even the notification emails are wrong :D
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-606797
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
