im in melb airport waiting for my flight home...
had a stag sus on the net and found this..
i havnt ran it threw fast yet but yeah...
the following dont line up for me...
all autechs have a rear fog on the drivers side in the reverse light, the tacho goes up to 10k, the front bar doesnt appear to have a 260 reo behind it... it doesnt stick out anything like mine... sits flush like an rs4,
u can also see the hack instal job of the guages.... the rs4, and rs4s? dont have the same mount set up in the dash...
it appears to be fake, and with that cluster in it im guessing fake KM's....
just a heads up to any buyers!!!
http://cgi.ebay.com.au/1998-Nissan-Stagea-...id=p3286.c0.m14
https://www.sau.com.au/forums/topic/285043-dont-buy-this-autech/
  • Replies 42
Either a nice RS4 or a butchered Autech.
Yeah looks like an 'old parts' bin. Good pickup RBPOWA - that's a series 1 auto dash. Pic' of a series 1 260RS dash, which Adam would be very familiar with too no doubt :)
Rear bar doesn't look like an Autech one to me? Got at the very least an aftermarket lower lip at the front. Doesn't have Autech wheels. Surely that steering wheel's a defect (no airbag). Are they aftermarket rear-view mirrors??? ;)
Edited by DaveB
Alarm bells are ringing for sure... the gear stick surround looks like a hacked auto job, but in saying that the seats look 260, the door skins also do, its an Autech wing and sideskirts. I would say seeing as its a new front, has no drivers airbag, and some other very hard to come by parts are mising like the cluster and gear stick surround that its been in a good front ender, scrapped someone took some bits off it and someone else has got some parts together to make it go again...
Either way STEER WELL CLEAR... even if it was really cheap, don't risk your life in a car thats probably been stacked
My 2c :)
This car looks to be a genuine Autech
just the cluster and Kms may not be genuine.
"all autechs have a rear fog on the drivers side in the reverse light"
not all that ture, just the stagea's that come from the mountain parts of japan(By there law they need 1), which is y some do and some don't.
"u can also see the hack instal job of the guages.... the rs4, and rs4s? dont have the same mount set up in the dash..."
Its just that- Hack install of the DVD,heater,guages and fold out screen, 4 things trying to fit into 3!! (seen this in a few jap cars)
The only 1 to get anything right was M I K E
"that looks like a standard series 1 manual setup to me?"
PS. This is not my car! just telling the facts!!
PPS Yes it is a joke of a Autech 260RS
I'm intrigued by that centre console: it's nothing like the one I bought from Nissan... Were s1 and s2 manual centre consoles THAT different?? Fo instance, the handbrake in that one comes out of the console top: my console has a moulding on the side, so the handbrake lever sits next to it...
i saw this stag arrive at Japlink Motors on the back of a tilt tray a couple of weeks ago, they had a hell of a time trying to lower it down off the tray, its front bar was ridiculously low
No 260rs on the back either that is tatoo'ed into the paint.
Mine doesn't have this.... should I be worried!?? Definately agree it looks sus.. and maybe, just maybe the people selling it have no idea.
easiest way to tell i reckon is look for the recessed area for the vacuum booster for the clutch, see if it looks factory (same as gtr's). Going by the pic it does look as per autech which is pretty hard to do unless u either have an autech lying around or a 32 gtr etc to cut the peice from. Though the pic is hard to see properly
does it have hicas?
measure the rear wheel base as wheel and get offset of the wheels and u can tell if its an autech cradle or not.
i assume it has brembos? what about the autech brace under the trans tunnel?
Edited by unique1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
