Hey all
Ive seen this thread topic on a few forums so i thought i'd start one here in the wa section of our forum.
Pretty much all you gotta do is say whats wrong with your skyline..
My problems are
my exhaust manifold gasket has blown out so now car off the road
i have no air con
my boot rattles like a mofo
my speedo intermittently works
hard to engage reverse
its an rb20det :D
What are your problems?
https://www.sau.com.au/forums/topic/285308-whats-wrong-with-your-skyline/
  • Replies 93
-F**ked Air Con (Got quoted >$1k to repair)
-Slight vibrations at idle when stopped at the traffic lights from time to time
-Lifter noise (tap tap tap...)
-Exhaust smells
-Head light cover have that yellow crap.
  • Very subtle rattle when idling
  • Squeeky clutch (on the way in and out)
  • It was doing that boost stall thing but that seems to be cleared up
  • A few pin dents that are turning into rust spots
  • Exhaust is too loud for my tastes
  • It's not a GTR :D
Exhaust smells lol i like that one. Smells good or bad, or just smells?
problem with my skyline is it only has 6 cyliners, not 12 and a prancing horse badge.
We will supaglue another RB to your current one and stick a prancing horse badge on your bonnet - all fixed :D
Smells like something is burnt, due to the new exhaust... thats bad I guess...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
