  • Replies 93
Posted Images
haha, I will try and get some taken tonight...give it a clean first.
My engine light come on the other day after I installed new headlights. (removed airbox and coolant bottle to get my hand in)
Had a look last night and one of the hoses from the intake pipe to the standard boost controller (only controls spikes) did come out, probably came out
when i was moving the afm around.
what would cause this?
cheers
only if you switch on the ignition or start the car with anything unplugged, and as cam said, it will be away about about 10 successful starts. i went to the dealer twice to get it cleared, but one time i couldnt be bothered but then it went away so i just leave it for a few days now............
So how much do you want for the rear muffler?
Given how huge the centre muffler is, not sure how much of a restriction it is, but it would be absorbing a tonne of energy/sound. Would imagine that the bulk of restriction would be in the 4 cats before you get to the centre muffler...
WTF..... 4 cats?
I only HAD 2. now 1 less.
If my memory serves me correctly, you've only got 2 cats Nick.
Dump & front pipe (as it should be from factory). Mine was the oddball exhaust, so don't go by that (dump, 3 or 4 in front pipe)
Edited by iamhe77
Plus the two in the exhaust manifolds (headers)... one on each side...
Need to have one in the manifold to be a LEV (Low Emissions Vehicle). These ones are supposed to remove all the nasties before the engine warms up properly..
che?
The VQ25det powered M35's were never a low emissions vehicle.
The PM35 was with the VQ35de and the VQ25dd, but never the turbo.
Pretty sure my exhaust manifold doesn't contain a couple of cats... but I feel the need to have another look now
RAWS Consumer Information Notice for my car states that 3 new cats were fitted at compliance :)
Two have the same part number and I assumed are in the manifolds area and the other third one, I also assume, would have been between the dump and the jumbo mid muffler..
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
