1993 R32 GT-R Midnight Blue/purple Pearl colour
Advertising this car for my Dad.
This car has a brand new engine, only has run 2000kms since rebuild. the new engine included cylinder bore, new pistons, new oil/water pumps, balanced and nitrided crank, full head service and porting and a 1.2mm Grex metal head gasket. I couldnt possibly list everything included in this build but the build also included two brand new reconditioned high-flow turbos. This new engine produced 305rwkw on an untuned Veilside ECU with A/F running well under 11 on 0.8bar (12psi). So there is ALOT more power to be made with a tuned ECU or PFC and boost wound up.
The pics shown really dont give justice to this cars colour, it is the best colour paint i have ever seen and grabs alot of attention without looking over-the-top.
List of other Modifications:
Body/ Asthetics:
- Full respray in Midnight blue/purple pearl
- Full Nismo body kit
- Powder coated rocker covers (candy apple red w/pearl)
- Polished plenum, intake pipes etc
Handling:
- Tein height adjustable coilovers
- Enkie 17X10inch wheels all round
- Strut braces and sway bars
Power mods:
- 2 x fully reconditioned and high-flowed turbos
- Veilside tuned length SS front pipes
- 3inch high flow cat
- Veilside 4inch cat back SS pipe
- Invidia 5inch SS Muffler
- HKS tripple plate clutch
- Trust Drag intercooler 4inch core (massive!)
- Blitz SBC-ID boost controler (fancy looking new one. 4 channels)
- twin HKS Pod filters with adaptors
Reason for sale: uncompliant wife!
Price: $39,990
Now $35,000
Pictures:
GTR 1
GTR front
Interior
Engine bay
Engine 2
Polished plenum
https://www.sau.com.au/forums/topic/28561-r32-gt-r-305rwkw-wpics-sold/
  • Replies 41
bbenny - i will leave your thread, but please read the rules - theres no advertising for other people on these forums, but because its your dad, i'll let it stay.
Christian
i am serious after a car now.... but when i look at the price tag.. ermmm i have to say no.... hopefully your dad can bring the price lower ,,,, then may be i or some orther people might be interested .... this is because your dad are selling an R32 GTR on an R33 GTR price
Yes, i understand there are alot of cheaper R32 GTRs around, but i have to stress that this car has a brand new RB26DETT. Everything internally is new and has been ballanced strengthened etc. over $14,000 was spent on this engine only months ago. and has only run 2,000kms since its rebuild. It puts out amazing power at low boost, and has had all its support systems upgraded.
The person who comes to see and drive the car will understand. So untill then go and buy an R33 GTR.
I agree with bbenny. Rebuilding the GTR engine is not cheap. If you include all the mods, custom paint & wheels you have to expect to pay close to what bbenny is asking.
You have to remember, you pay for what you get. I've seen alot of R32's that are cheaper but miss the quality.
If people aren't interested in purchasing, complementing or requesting more information, there is no need to post such replies to threads such as this.
Take it or leave it, this is just my 2 cents.
All the best with your sale bbenny.
keep the offers comming, all reasonable offers will be considered.
Ben.
What exactly was done in the rebuild of the engine (what parts were used?).
Does it have standard injectors?
Are the turbos ball bearing? When does the car make full boost?
I'm possibly interested in your Dads car if I sell my current car before this one is snapped up.
Well the engine rebuild included a full head service and porting, bottom end had the cylinders bored slightly so there is a slight increase in capacity. also a tomei oil plug or something was used (i dont know exactly what that does stops oil surge on launches or something?) the crank was balanced and nitrided/strenthened) all new pistons to fit the larger bore. new oil and water pump, trust metal headgasket. i dont know the exact specs of the turbos, but the quote read "high-flow ball bearing turbos" - as for full boost what psi do you consider "full"? it makes 12psi at about 3800rpm - compared to my RB20 with a 2530 mine feels more laggy. there is so much to list as to what went into the build. give me your email address and i will send all the details to you if you like.
Ben.
Ben.
You have standard pistons which means i'd have spend about $5k to replace them with forged items. This includes replacing the head gasket, pulling the engine out of the car, purchasing the pistons etc.
I'd also have to get some aftermarket injectors to replace your standard ones while also replacing your ECU with a powerFC or similar. AFMs will need replacing if I get the car tuned properly at higher boost.
Let your Dad know that i'll offer $32k for it if the clutch is not too much of a pain.
exactly what i was thinking mark!!!.. awesome car..but whoever buys it if its not me has alot of work to do ..and its a big project and alot of hassle once ure talking 300rwkw+...
benny.. can u please pm me ure father number again?? thanks
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
