  • Replies 328
aahhhhhhhh crap,
i just realised this is on the saturday not the sunday. that means i am OUT :cool:
forgot i have stuff on that i cant get out of on the saturday. damm damm damm.
looks like i will have to wait until next year now.
I was always coming to this one (the only one I go to) like every year. Hopefully my new radiator will be installed in the next few days.
Just wondering is this skylines only cruise or any car cruise??? :rant:
Dave
Guys I am really sorry to do this, don't think this cruise has ever been THIS popular. Due to the amount of people coming I am going to have to restrict it to Skylines and SAU members. Just booked the place for lunch and they can barely cater for the amount of people currently on the list. .
really sorry as I normally don't ever say no to bringing non SAU people along!
edit - if you are already on the list then it's ok cos you are counted.. no more extras sorry!
yeah but im only a member on this site, im not like a paying member or anything, does that matter?
i really do wanna go
Better still... Fill out the membership form and join SAU NSW on the day for a few bucks?
You've already expressed your keenness > no initiation test hehe
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
