My 1st Time @ Winton Drift Experience
Hey guys, So it was my first time at winton drifting! It was so good! I also entered the track and it was unbelivable! it was the bestest experience ever. My car was running at 233kws and thrashing it the temp was at 81c with a alloy radiator! . For drifting i had a 2way diff , coilovers and a rear adjustable sway bar! but the bad thing was HICAS was activated... i hope it didnt make a diffrence.. I also spun out a couple of times onto the grass! . I went through 1 pair of tyres and also used not much petrol? . The morning was also cold but then in the afternoon it got pretty hot. I also saw 2 SAU members RED r33 drifting he was going off tap going nuts.. and i saw a White R33 with a Camera on top.(had a SAU sticker) . Anyways who else went?
w2048.png[/img]
Edited by geraus
https://www.sau.com.au/forums/topic/286737-my-1st-time-winton-drift-experience/
Yeah mate, white R33 was me. I had a great day. Looking forward to the next oppertunity I can get out there. Only way to get better is just keep on getting as much track time as you can.
Hey guys thanks heaps for the comments!, Yeh i have experience lol, street experience, i can connect the far far away big S-bends......... but the thing is HICAS is stufffing me up! WARLORD you should come down its really good! guys should come down!
car looks nice mate, how was it first time drifting? you had any previous experiance? im really keen on going onto the track for drifting but i have NO experiance drifting.
You need to man up Bas and give it a go! I'll drive your car up there for ya!
Good stuff geraus. Looks like a good turn out up there.
Did you improve Brendan? How did ya go?
We're hoping to make the november or december one in the new car.
im gonna hold you to that russ, you can just swing past mine, and then we will cruise it there (with you driving mine obviously)
when is the next meet?
if its november/december, then my high mount setup and 2 way diff will be in 100%, if not then just the 2 way will be in lol.
thanks russ :banana::D:D:D:D
hey geraus
tets' lover hahaha
good to see you learnt from my teaching of drifting.... if it wasnt for me you wouldnt have known how to link the S bend with a slight tap of the brakes for transition lol
good to hear u had fun man
p.s. u know me from west meet (tets' mate)
thanks russ :P:D:D:D:D
The december one is probably more realistic with the sil so that would be a good time I reckon.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
