  • Replies 73
Posted Images
Ok no this is what i meant...IF i have to cut a huge chunk out of the Front REO then cutting 1 more hole isnt going to make a difference to RTA/Police is it.
I think a cooler pipe out each side of the cooler looks so much nicer.
The Blitz 1 uses the standard pipes which is great and will work if i only got to trim the bar slighty then np ill go blitz.
The XR6 cooler dunno how good they are my mate installed 1 in his TX3 but im sure they have a fair bit of PSI drop but that was the 1st style FMIC from the 1st XR6 Turbo.
and PWR coolers well i have heard nothing but good things about those coolers my mates RX3 has 1 its got over 400rwkw and his is a huge FMIC.
the blitz cooler has won my heart i will be buying one when funds let me BUT... just wondering in the pics of the cooler the pipes are really shiney but in the pic of your R33 they dont look that shiney any reason?do they come shiney like that?
wow, got an email quote for the blitz lm, and it was 799 from auto barn, so i went in hoping to buy it, but they said 1600.!!! WOW
then i asked about the greddy hybrid tube and fin and that was 1100.!! and its like the one i got now so it does not fit nicely, none of the holes match up to any bolts,
abit overpriced,
think im going justjap for the first time, are theyre postage prices decent?
and for the blitz lm/cs, what extra pipes do i need going from a standard fmic?
abit overpriced,
Blitz LM is the old version.
Just Jap has the new Blitz CS kits for $799.00.
Considering they are the sole Australia Blitz Distributor you can't really go wrong, plus they are a forum sponsor :happy:
Ok no this is what i meant...IF i have to cut a huge chunk out of the Front REO then cutting 1 more hole isnt going to make a difference to RTA/POLICE
reo bar is replacable, alot easier to fix up, the hole underneath the washer bottle is harder to patch up.
Any pics of it installed? I'm thinking of getting one to replace my old GTR intercooler with the over-the-rad piping.
Theres a couple of installation pics on THIS page, and installed pics on page 1.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
