Hey guys ive got a 2d NA r34 and am not to great when it comes to wheels and fitment.
Just wondering, i want to fit 18x9 +33 on the rear and 18x8 +33 on the front. Will i have issues with break clearance and will i need to roll the guards ??
Depends what tyre size you run and how low it is.
Personally I think they'll fit easy.
My mate just fitted some CR Kai's on his 25GT.
Front: 18x8.5 +30
Rear: 18x9.5 +20
We're going to have to roll the rear guards when he lowers the car.
The specs of my NA in front are:
Front: 17x8 +/- 0 offset.
Rear: 17x9 +13.
I'm running fairly stretched tyres and camber to fit these in. Guards are rolled too.
Edited by -Jimmy-
you'l be sweet with that size, i put 18x9.5 +40 with 235x40 tires on my r34 and only experinced a small bit of scrubbing on the inside front well gaurds when turning at full lock, but it doesnt take long for the tires to cut a groove thru the plastic and now the scrubing is gone
Roll it and you'll be sweet! As far as I know the NA's and the turbos have the same wheel clearance and I will be running 18x8.5 +30 and 18x9.5 +35 on my car when my wheels arrive.
[/quote
whats all this talk about rolling for? ive lowered mine quite a bit (cant fit fingers btw tire and wheel well at the rear and in the front i can just fit my fingers in) and i have no trouble
I thought you "cut a groove thru the plastic" though? You were also running a 40 offset though, dunno what difference a litle bit will make.
is dish the same as offset? lol, maybe a stupid question, maybe i got 40mm of dish, because my rims put most of their width toward the outside of the rim...
but i was just wondering why 'roll' a wheel well, because yes mine cut a groove thru the plastic on the inner-most part of the wheel well(front only and at full lock) , but doesnt 'rolling' refer to the metal lip of the wheel well being made deeper?
Edited by AYW550
AYW550, dish and offset are completely different. (Although the amount of dish is determined by a combination of the design, offset and width) Generally the greater the width and the lower the offset the more dish you have.
The offset is determined by where the hub sits in relation to the middle of the wheel, if its right in the middle offset = 0, if it is 30mm towards the outer edge of the wheel then the offset is +30. Thats why a wide wheel with a low offset sits out far and can create more dish. (sorry if I'm confusing lol! I can explain it well in person with a wheel as an aid).
ok cool, nope not confusing, now i know that it is 40mm of dish that i have, due to the width and location of the offset. so infact i probably dont have much offset at all
im running 17x9 +20 on the front with 225/45. sits flush
and 17x9.5+18 on the rear with 235/45 (will be 225/45 soon) and wind out some camber on the rear.
Edited by 4 door love
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
