Have you seen any more power Nathan from more boost?
Surely valve float isnt too far off
my standard coils were breaking down at 23psi and i haven't had a chance to put it back on the dyno since i replaced them.
how do you guys control boost with those sort of setups? wastegate mounted off the exhaust housing?
i changed from a .82 to 1.06 (havent yet retuned) and added a bigger gate (44 to 48mm) and it started to boost creep madly from there.
i've got a twin scroll manifold with twin 38mm gates, so far boost control hasn't been a problem but we'll see what happens when the 1.06 housing goes on.
  • Replies 112
the manifold is probably your issue the gate pipe exit angle is pretty severe and we have had to mod a few to make work properly.
here is an original picture of the manfold. URAS do you have any pics of your modified ones, would be interesting to have a look. id also be keen to have a look at a few that are straight out of the housing.
its since had the wastegate pipe moved further into the gas flow, and ive upgraded for a 48mm gate (from a 44).
i think just putting it off the housing will solve the problem once and for all hopefully. the manifold maker has been mucking around with this for ages now and i dont really want to spend the $$$ on a 60mm gate even though that will fix the problem.
will be interesting to see what sort of power i can get.
8.5 comp ratio with stock r32 head with valve springs and camgears 1.06 housing. 310kws came on the .82 on 19psi.
Edited by SirRacer
Wasnt there a thread about this somewhere....all merge collector manifolds with gt35r turbos and up seem to have this issue...the manifolds flow so well that it bypasses the pickup for the gate, smaller turbos on those manifolds seem to have enough back pressure in there to force gas out the wastegate.
To fix it, the wastegate pipe needs to protrude further into the gas flow inside the collector to catch more gas and direct it out...otherwise block it off and put the wastegate off the exhaust housing. Weve done that fix several times now and it works great. The manifold builders know of the issue, but i dont think they like the idea of disrupting the excellent flow they have through there. But i think perfect boost control is quite important. Probably abit more so then having perfect exhaust flow/spool.
Yep - i even tried a quick search for it last night actually hehe.
Pretty sure it was the 1.06 housing ye?
I remember a thread on it, quite detailed, but just didn't have the time to find it.
Would be 12 months ago now at a guess.
Its just plain bad design, 90 degrees off the collector is never gonna work on genuine high hp stuff and it doesn't. We have had to extensively modify them (dual outlets to gate) to work properly.
Thanks mate, that looks good.
I found another from the Heat Treatments world record holding GTR. This is from their new turbo setup (looks nasty).
http://www.htlracing.co.nz/images/200935020th002_008.jpg - I thought the distance between the housing and the gate is quite interesting.
hmmm, no idea why they would do that. i would have thought for optimal operation of the gate and gas flow, the gate could sit right on the housing. so that the piston/button in the gate is level with the inside surface on the housing. no doubt they would have their reason tho.
i also wonder whether having the gate coming out of the housing is much better for spool. considering the fact that exhaust gas spools the turbo, having it run through the exhaust housing (and therefore wheel) rather than been bled off, must be a tiny little bit better flow and responce wise?????
having a gate off the housing has nothing to do with spool. all it does is control boost. not how fast it makes boost.
the downside to having gates off housing is that you pretty much kille off any chance of a resale as it's not a highy wanted modification. personaly it just seems very backyard job.
that's my view on it anyway.
just remember you don't have to have theg hate off te housing. it is 99% th fault of a badly designed manifold. although it is alot cheaper then buying or sometimes modyfying the manifold
Edited by Jap_Muscle
I'm sorry buddy but you've got it completely wrong. the only reason a manifold has problems controlling boost is of poor design. if you bought a manifold like this you either
a. do not know how a forced induction system works
or
b. you wasted money on a shit manifold.
you need to understand that building boost and expelling boost are just as important as each other. if you only have one your fooling yourself
or
I'd be blaming the guy making the manifold not the end customer! The manifolds in question come from the most popular manifold makers in Aus....
not poor design at all, its poor placement of the wastegate port.
which is poor design
aint you also running his manifolds?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
