The CE28's look the best I reckon... LMGT4's are definitely cool though... tough choice hey!... top shelf parts selection and you got it built at the right place... now stop holding out on us, we want to see the dyno chart!
Agreed the CE28's are my favorite wheel. :domokun:
A Power FC retune yielded a slight increase in maximum power output, possibly due to larger intercooler:
I will keep this thread alive by updating periodically
Hi,
Just wondering, this power was achieved on standard injectors or?
What boost pressure did was it on?
Beautiful 34 you got there, keep up the good work.
Cheers
Grant
Hi,
Cheers
Grant
Hi Grant,
The power output was achieved with standard fuel pump; standard camshafts; and standard injectors. Its surprising sometimes how good the factory stock parts work.
The boost pressure was about 1.3 bar, with NO electronic boost controller, just HKS actuators and a factory solenoid with a bung in one of the hoses.
I guess that is Racepace tuning philopsophy - keep it simple and achieve maximum result! (BTW I have no affiliation or financial interest with Racepace.)
Cheers
Matt
Thank you for all comments and encouragement!
Better do something bout those brakes. Look a little small behind those rims.
Since someone mentioned brakes, below is a detailed pictorial of the AP Racing 6 pot front; 4 pot rear Formula Big Brake kit.
Front caliper 6 pot CP5555:
Rear caliper 4 pot CP7618:
Size comparison:
Front mounting bracket at an amazing 0.8kg and super strong
Front 'Strap Drive' 2 piece slotted 355mm disc:
Rear one piece cast slotted 320mm disc:
Interesting to see that the front disc at larger diameter weighs less than the smaller cast rear disc.
Ferodo Racing DSC 2500 pads (should've bought DSC3000 instead.. DOH!)
Braided brake hose and tubing:
Dot 5.1 AP Racing brake fluid:
Final installed:
GTS4WD Posted Today, 11:49 AM
Stupid qestion one for the day:
What is V-cam?
V Cam = HKS variable cam on intake side for RBs
Aaron34 Posted Today, 12:01 PM
Hey, you should have just bought my car instead and saved yourself a fortune... What exhaust are you putting on it now if the RPM single is coming off?
Hey Aaron,
It would have definitely been alot easier just to buy your car, but then I miss out on all the fun and excitement of building my own car to my own specs.
In terms of cost, it ended up almost the same as the 'trade in' price you wanted for your car at that time :laugh:
One of my friends is interested in building a RB28 GTR, so I will try and convince him to look at your car if its still for sale!
As for the exhaust, I had one made similar to what Ben has in his R33
Pictorial of HKS V Cam unpacking:
Special Intake Cam "V CAM" : 248° Valve Lift 8.6mm, Phosphate Treated:
Special Intake Cam Cover (HKS POWER logo gives extra street cred):
VALCON(V CAM Specific):
Nickel Plated Duralmin Intake Pulley:
Extract from HKS European website:
Using variable valve timing technology, V Cam System evolves the RB26 engine to a new level. HKS V Cam System for RB26 addresses the issue of low-mid rpm torque whilst allowing the engine to continue producing power at high RPM.
Features:
The intake cam side of the RB26DETT is changed to allow variable valve timing. The Cam used has a duration of 248° which can seem a little conservative. However with the variable timing, power increases can be found at low or high RPM
Whether you are looking to find some time on the circuit through improve acceleration out of lower speed corners, or simply want something which can overtake with ease on the street, the HKS V Cam System provides good power from low RPM reducing the necessity for excessive gear changes. This especially noticeable when going from vacuum to boost to give the feeling of increased displacement.
Improved valve timing will allow for more complete combustion leading to improved fuel economy and cleaner exhaust emissions.
HKS V CAM System is available in 2 versions. Type A, which can be fitted to a standard engine (Valve timing adjustment 30°) and Type B, which can benefit from further valve timing adjustment (50°) through the use of HKS Pistons.
Type A was chosen as car is intended to be street orientated.
Hey Matt
Did you import the V Cam kit yourself or did you buy it from an HKS dealer here. The reason why I ask is if you bought it from o/s, you're going to have a tough time getting it tuned properly in this country as HKS will not supply the software to tune the kit unless you bought it through an Australian authorised dealer. Someone I know went and bought his kit o/s, got it installed through Bel Garage but could not get the software to tune the damn thing.
So just be wary of that.
Hey Aaron,
Either you haven't got your labour bill yet, or the parts you bought are hot. At my advertised price of 89K, I'm not sure how you could build up one of these including the car purchase price. I know mine has over 100K spent on it then there was the price I paid for the car itself...
I'd love to get around to putting the variable cam set into mine one day. Its already insanely torquey with the 2860 -5s and the 2.8 HKS step2 kit.. (plus all the other top secret stuff of course) I'm still running the standard intercooler and plenum. I see you changed both of those... Is your's running yet? I heard it might be..
mxfly Posted Today, 06:44 PM
Hey Matt
Hi mxfly,
I had this discussion with Racepace prior to ordering the V Cam and Ben guaranteed 100% that he will be able to integrate it with the Power FC with no software of hardware technical problems, and guess what... the man delivered! I privately imported the HKS V Cam direct from Japan. I managed to find a copy of the installation and software set up manuals in English which helped a lot.
two_evil Posted Today, 07:02 PM
yeah exactly i think you need to use a hks f con v pro to use the v-cam. other wise u can't tune it. sucks ass. i think you might be able to haltech to control not 100% sure
Hi two_evil,
I was a bit sceptical at first whether the V Cam will be compatiable with the Power FC, but the result has proven that it works very well. I was told that the Valcon does not talk to the Power FC at all, it merely acts as a piggy back computer changing the Cam angle according to engine speed in rpms.
Initially I was going to buy the HKS f con v pro, but the cost is prohibitive and HKS will not sell you one unless you purchase direct from the Australian distributor and on top of that, no one can tune a F Con except the distributor in Sydney.
I took a bit of a gamble to outlay the cash for all this V Cam stuff when I only had one man's word that he can make it work. It just shows how much I trust my workshop.
Aaron34 Posted Today, 08:10 PM
Hi Aaron,
Your car now at $89k is an absolute bargain for what you get! Back then when I inquired you about it, you were a lot firmer with the price.
LOL regarding the 'hot' parts.... I actually have good contacts which allowed me to get exceptional deals on JDM car parts, besdies the Aussie dollar at the time was in my favour. I must admit the labour cost was the killer. Don't forget your car has fully tuned suspension, drivetrain etc. which my car does not.
The car is running well, I will post dyno graph soon.
Matt
I hear it is awesome. We should meet up and swap some knowledge. I'd love to suss out the VCam and I'd be happy to take you over the rest of my car and where all the time and money has gone...
Beno knows how to hit the bullseye with all of it now, but it took time. The 33 is a totally different chassis. Great thing with Beno is you feed back the cars behaviour and how you want it to behave and after an exchange of time and money, you get exactly what you want. I don't know anyone else that can do that as well.
I've only put about 3000 ks on mine in the last 20 months, basically since the build. Damn waste. Winton in a couple of weeks should be a good test for it...
Hey Aaron,
The issue I have now is that the car is too fast for me to handle safely, I get scared when I go full throttle. :)
I wish I had driving skills like yourself, Chris and Jack.
I need to learn how to drive the car! Definitely catch up.
Cheers
Matt
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
