BTW, I picked up yet another set of wheels from Yahoo japan. I know what you guys are thinking, but I just love this JDM stuff!
The obligatory pictorial:
Specs:
Fabulous Expand Racing R, Forged, high quality, brand new
19"X10.5" +22 offset; same as my previous Rays CE28Ns
Mega lip and plenty of 'bling' 'bling'
No blow off valve. The key is stealth. You will be surprised how quiet the engine/exhaust sound is at idle, almost stock. When you rev it high, it howls much like the Mines R34 car.
Tangomatt, i love everything about your build so far...but im just not seeing the excitement in these rims.
couldn't agree more.. :) but i suppose it might all fall into place when on the car..
as for seeing it in action, bring it to a deca thats no doubt the safest place to give it a flogging
Just read through your build and Im crushed lol I so want to build up my car like this but yeah dont have the available funds yet, but well done on it great to see the commitment you put in and stuck through it and got it finished its unreal the car. PS you really love your rims lol.
Very sweet car. <-- understatement of the year...
I will say one thing however - you have way too much $$ for your own good... :rofl2:
If you don't mind me asking, how much has this all cost you (roughly)?
Edited by gwilkinson34
Nobody will ever answer that question.
Usually because all the recepits have been thrown out. This way your not tempted to add them up and weigh the dollars spent with the fun you get from the car. And of course no reciepts means it technicaly cost nothing!
I honestly don't know exactly how much has been spent on this project as I have bought and sold parts along the way.
One thing I know for sure is that there are many other builds in this forum that cost much more than mine. :down:
One thing I know for sure is that there are many other builds in this forum that cost much more than mine. :D
Yeah!? Really!? Like who!? Tangomatt, we all know you're being modest. :)
Edited by AtomicBomberMan
Hi all,
Just a quick update on the suspension upgrade with Racepace customised Tein RS setup.
The Tein RS, aka 'Circuit Master; Super Racing Spec', has been out of production since 2006-2007. They were the top of the line in the Tein catalogue for production cars at that time. In some ways, I feel that the materials used and the way it was manufactured surpass what's commonly available today, even the premium priced shocks.
Details of the RS are listed below (sourced from US based my.is forum in 2002)
MATERIALS AND FACTS:
DAMPING MECHANISM:
45mm diameter pistons
Double shim stacks (near unlimited tunability with knowledge of shim valves)
Two 'special form' adjustment needles
SHOCK/RESERVOIR BODY:
Monotube shock body
53mm outer diameter
Aluminum alloy (A7050) seamless tube, CNC'ed, green (hard?) anodized
Inner tolerances:
diameter: ±5µm
roughness: ±1.6µm
Reservoir body interior is PTFE (Teflon) coated
CNC'ed aluminum alloy eyelet, Tein rubber bushing, steel pivot
SHOCK SHAFT:
14mm diameter
Chromoly (SCM435) steel, Ti-N coating
SHAFT SEAL/GUIDE:
WRC spec
PILLOWBALL MOUNT:
Aluminum alloy, CNC'ed, powdercoated (gold)
SPRINGS:
Main and helper
Steel, ground and tapered, enameled
10K front, 10K rear
SPRING PERCHES:
Aluminum alloy, forged and machined
SETTINGS:
-34mm front, -12mm rear (easier measured as 335mm both from the center of the wheel to the fender lip, front and rear)
10 clicks rebound front
10 clicks compression front
10 clicks rebound rear
13 clicks compression rear
Out of the box, the RS will not suit my purpose of a street orientated setup in Australian conditions. So the solution Racepace derived is to employ a high quality, well engineered shock to begin with and customise the valving and spring rates.
The current spring rates are less than half of 10K front and rear. The exact rate Racepace did not divulge and so is what they did to the revalving. BUT believe me, the setup works very very well.
My initial impression, compared to the Nismo S Tunes, which is also street orientated:
- The damping is comparable, soaks up bumps and road undulations well. The rebound is quicker than the S Tunes, that the RS is less 'cushy'
- The car feels more planted and can hold its intended steering path despite mid corner bumps etc
- At very low speeds, the RS is very compliant
The only annoying thing is an annoying 'whimper' originating from the rear shocks at very minute bumps. It almost sounds like someone rubbing a wet finger on clean glassware. However, I did some research and found that this is quite common, and indicates no fault. The pillow ball mounts also transfer more road noise to the cabin.
I spent a good afternoon with Chris from Racepace. And this is how I feel as a passenger..... Well Chris test drove the car in a 'hill' run. (Chris is an excellent driver btw. He scared the sh*t out of me)
- The car feels like its on tracks and bumps do not upset the momentum.
- Car feels planted, period!
Chris comments that the RS allows him to transfer weight nicely and from the get go the setup is confidence inspiring. That is he can drive a lot quicker if I was not in the car with him. He was extremely happy with the way the RS can handle the low speed stuff equally as well as the high speed.
Overall, I am very impressed, bearing in mind that the Nismo S Tunes were very good to start with. I highly recommend it to anyone wanting a street car to go for less spring rate but good damping force.
Final thing on the agenda - increase ride height on front end and transfer case reinforcement.
PS will post pics on weekend.
Cheers
Matt
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
