hey all...
been scratching my head at this one since i got my car back from tuners.....just neediing to know what is a safe amount of knock for a tuned vehicle.
what is your oil temp (with oil cooler) max on a hot day and whats safe???
what is your water temp on your pfc controller on a hot day max out at, and whats safe??
cheers in advance,
my water temp is at 81 with a alloy radiator
my knock is about 10-15-20
and when i was drifting at winton my knock would be about 15-20
and temp would be 81 usual on a sunny afternoon :D
was just thinking this today as i noticed my safcII reading a bit higher then it normaly does.
when i first installed it i didnt think the knock function worked coz it always stayed on 0, then after about a week i noticed it would read 1 or 2 & after a long drive it read up to 12 but today after slapping it around corners in the wet lol it was reading 16. all my readings are at idle its never read anything other than 0 under load.
does this sound fairly normal?
Knock up to 50 is quite fine under full load, i.e. 3rd/4th up a Hill on a Freeway, etc..
Water temp ideally should be under boiling point, but best under 90 degrees, because at 90+ timing gets pulled back 5 degrees, more or less depending how the powerFC is set up.
Oil, you would want it under 100, 110, I've seen mine go up to close to 120 on a skidpad sitting on the limiter in 2nd for quite sometime.
With an good oil cooler, your temps should never past 100, and below 80, i.e. the oil cooler setup is also running a thermostat, there's nothing worse than 'over cooled' oil.
not sure about the rest but water temp with thick radiator sits at 86C cruising ... r34 thermostat opens at 82 so that's normal (bit lower for R33s as the ts opens at 76)
Is that true that the PFC pulls timing if temps get over 90C?!
My R34 consistantly runs in the 90's during summer since I installed a FMIC. I pulled out my radiator yesterday in the process of replacing the timing belt, and discovered it was in very poor condition with many bent fins... Might explain things!
In any case if it pulls timing I think I need to look at getting a new radiator.
there is a water temp timing trim option in the power fc yes. what it is set at I cannot tell you as it can be changed with dataglogit.
I think its time to change your location guilt-toy, but from the youtube videos i have seen your avatar is spot on :)
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
