Where Do You Wash Your Pride And Joy?
i dont wash my car anymore, i get it handwashed properly by other people. i used to go to the self serve car washes but it used to cost me alot and after i've finished its still dirty, none of them clean my black car properly.
I wash my cars weekly (minimum) at the car wash on the corner of Boundary Rd & Lower Dandenong Rd.
Some times I use Ezy Bay car wash in Highett because it's near my house, but they don't let you hand wash like the other one.
I get the indian dudes at magic carwash to do it for me
$15 and they do a good job everytime :)
is that the new one that opened up near burvale on springvale rd near burwood hwy
i wanna try it
is it expensice
Hey guys,
Just wondering where abouts (other than at home) you guys wash your rides?
I've only been to one hand carwash in Burwood and it seemed OK.
If theres anything that makes the place better than the rest, shout it out!
I use the sparkling car wash in Burwood. It's right near the Vicroads. Good for bucket washing when times are quiet. Always have fairly clean bays too, and plenty of space to chamois or clean/admire your car.
I wash mine at a self serve place called "Pitstop" on High street Reservoir - near the KFC and Caltex.
$2 for 2 mins. Reasonably clean bays, the soap seems nice and strong especially on Tuesday nights - I'm guessing this is when they re-stock.
They have hand wash service during business hours and weekends - but I've never used them for that.
Tends to get 'crazy' busy, especially when the weather starts warming up.
Anytime after 10PM it is deserted.
I usually wash my car there after a night out - around 2AM.
I wash mine at Budget car wash on Ballarat Rd. $1 for 2 mins, I always hand wash it and it cost me $2 to get the job done. $1 for 5min to vacuum, $2 to shine the inside. Cost me $5 all up to get the car pimpin!!
Correction - it is $1 for 2 mins NOT $2 for 2 mins.
wow im surprised how many ppl on sau actually go to and use that sparkling cvar wash on burwood hwy thats pretty close to my house i always drive past i rarely see skylines there lol. i use sometimes the bp ones but my favourite is the aspendale gardens car wash corner of springvale n wells road.
Gee thats the one -i- always use in melbourne, what a coincidence!
wonder why... :blink:
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
