iv'e just got -7's installed and not hitting full boost till 5000rpm.
my mods include...( exhaust, PFC, adj camgears, -7' turbos, hks actuators. )
currently boost is tapped into the stock boost controller.
things that have been checked by my tuner.:
- boost leaks
- cam gears in right position
- vacum leaks.
- tightened actuators, ( but when its tight i hit 20psi of boost which i dont want )
- loosened actuators in order to stay at around 16psi.
my tuner has suggested that i get a decent EBC so that he can tighten the actuators off as that
may be a reason for boost leak?? ( but im not sure how much this will fix my problem )
The power is there once it hits boost and on the dyno ran 288kw at the rears on 16psi.
My dilema is that it takes for ever to hit full boost.
Just wondering if there was anything obscure or even anything simple that may have been missed
that i might be able to check/replace/tighten etc...
Any experience or suggestions would be greatly appreciated.
cheers
loc
https://www.sau.com.au/forums/topic/288089-garret-7s-just-installed/
I used a turbotech boost controller (essentially a pressure reducing valve) on my Legacy GT. Cost $30 or so delivered and the boost came up fast and smooth. With a 4psi actuator (stock for most ecu controlled turbo systems) and the valve set so that I would just miss the boost cut (14.5-15psi) I would get 12psi in 1st, 14psi in 2nd and 3rd, 14.5 in 4th and 5th. On cold nights it would hit the boost cut under heavy load (ie car not accellerating much but at full throttle for a while).
After fitting the large exhaust the boost rose maybe 1psi in all situations (so I had to back off the boost controller to avoid hitting the boost cut), and I was able to get 13psi in 1st while still avoiding the boost cut.
I really don't see why you need better boost control than that, and it's worth spending $30 on something that has a good chance of working (and is easy to set up) before spending $300 on something that is guaranteed to do the job but takes a lot more to set up. Plus you can sell it again if you don't use it.
Incedentally taking the wastegate line off saw no change to boost response below 9psi with this particular controller, so no boost controller is going to bring boost up faster to that point without an anti-lag system.
run a line and t-piece directly from the plenum to the actuators, preload the actuators to about 2psi lower than the boost u wanna run then put a turbotech in and wind it up to the boost u want. This setup will give u pretty much the fastest possible boost response.
An EBC wont make that much difference - esspecially if you've allready put more preload on the actuators and your still only getting boost at 5000rpm. Still sounds like you've got an issue.
Roughly how many rpm is "much"?
Want to know how much? Disconnect your wastegate lines and go for a very careful blat. No boost controller, however many lights, buzzers, displays, and functions it has, can get better than that regarding lag. Just be very careful that you don't over-boost, as I'm assuming you no longer have a boost cut. With no functioning wastegates, your right foot can be stronger than your engine (except for GTR700, but that's too cool to mention again in this conversation).
If you still have lag issues without the wastegates connected, you have other issues.
-Ben
thanks for the replies,
i think i may not haave been totally clear,:
i wasnt after info on which boost controller is best, more so, whether or not
installing an aftermarket boost controller in order to tighten/seal off the actuators will
help boost come on quicker..
or even if there where other mechanical malfunctions that may be causing the lag.
im starting to get paranoid now and hoping its not one of the turbos, or both.
To clarify, i'm interested in what the difference is between a manual boost controller (spring + ball type, not dumb bleed valve) vs EBC. Ballpark. 100rpm??
A turbotech and an ebc with the gain set to max it'll go without spiking will come on to boost pretty much the same so i'd say zero rpm difference.
Hi,
Certainly sounds strange that the turbos are not boosting up sooner. In my R34 GTR, these turbos would be spooling up around 3k to 3.5k rpms and pretty on full boost by 4k rpms. I doubt that its the turbos' fault as they were running fine before they were dismantled from my engine.
Hope you get it sorted out.
Pm me if you have any concerns re turbos etc.
Cheers
There is NOTHING wrong with the standard boost controller! I was running it coupled with a special piece of tube to increase boost, with excellent response and flatline hold.
What are the cam gears set to? Advance inlet, retard exhaust? This combo brings boost on nice and early.
What AFR does the car run while building boost? A lean or excessively rich tune while building boost will make it much laggier than it should be.
yes...spot on.
I am about to get some 2860-5's and was going to use adjustable Cam Gears. However I am also being strongly advised to by some Tomei Type B Poncams as well. Are the response gains from the camshafts worth the outlay?
Edited by gtr fan
Shit yeh. Tomei already use different cam timing for best balance of response and power so the cams wouldn't cost as much if u just get the cams without gears. Most tuners don't take the time to tune cam gears to their best anyway.
Souonds like cams are the way to go. Out of interest have you discussed cams with your tuner lololoc?
Edited by gtr fan
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
