hey guys, we have a variety of r32 parts for sale, all off a r32gts4, everything from a 2 door... pics available upon request, otherwise we will slowly get them all up...
r32 passanger side door window $60
r32 " " window assembly with great motor $100
r32 rear seatbelts with buckles (all 3) $80 for the lot or $30 each
r32 gts4 seats, in great condition, no rips or stains $150 each $200 for both
r32 rear seat (base and back) in top condition $100
r32 gts4 roof trim, complete, good condition, no damage, no sunroof $80
r32 gts4 trims (behind the doors next to the rear seat) 1 is in great condition, other is missing the trim: $60 and $40 respectively
r32 gts4 center console, great condition, with all components working A1, no handbrake boot... $60
r32 gts4 center facia (the surrond that goes around the headunit and gearstick), in reasonable condition $40
r32 rear parcel shelf, in good condition, not cracked or broken... $60
r32 gts4 complete carpet, in really good condition $80
r32 gts4 glovebox, in good condition $50
r32 gts4 rear passanger handles (the ones mounted on the roof) $20
r32 gts4 center console part of the dash, great condition $70
r32 gts4 kick panels, have both sides, in good condition $30 each or $50 for both
r32 skyline sill trims, both side, great condition $80
r32 gts4 boot carpet, great condition $30
r32 gts4 boot trims (the main two big peices that go over the wheel arch and back) $70
r32 gts4 b-c-pillar trim, ones in reasonable condition the other not (drivers side) $50
r32 gts4 a-pillar trims, good condition $50 each or $75 for both
pioneer carrizora (or something like that) rear speakers (there are 4 speaker things on each) $70 for the both
r32 gts4 passanger door handle $10
r32 rb20 polished camshaft covers, only just recently done... $200 for the pair
r32 rb20 ported and polished head, with lapped in valves, and standard valvetrain $600
r33 rb25 polished camshaft covers, missing breathers $220
r32 rb20det camshafts, in great condition $80 pair
r33 rb25det VCT camshafts, in great condition $100 pair
r32 polished CAS mount $60
r32 rb20 polished intake manifold (standard type, with ported runners) $200
r33 rb25 polished intake manifold $250
r32 T3 flange top mount stainless steel manifold with wastegate pipe... good condition $180
r32 T3 standard turbo, with snout, and dump pipe, negligent shaft play... $150
r32 polished standard fuel rail (with reg etc) and injectors $60 and $80 repectively or $120 for both
r32 rb20 standard turbo manifold, great condition $50 suit rb25 too...
r32 turbo dump and front pipe in one... great condition $120
thats bout it for now, please PM us, or reply here and we will contact you...
located near lismore NSW, can deliver any item personally as far as Brisbane QLD, otherwise postage is okk with the smaller items...
cheers guys.
also everything has been removed due to turning the car into a track car and upgrading the engine/ everything...
Edited by sebastion
rb20 covers, plenum, under plenum and injectors, manifold, variety..., cas mount (rb), rb20 head, more to come...
hey just wondering if u have any suspension coming out of the gts4?
hey mate, yeah we will do sometime in the future, what exactly are you after? please PM us
any chance you have the stock r32 steering wheel?
yeah mate, sure do, its in good condition apart from the horn (the plastic inside is stuffed)
cheers
Received item on Monday :) ...that was fast
Thanks heaps!
no worries mate, thanks, and hope you enjoy.
cheers
rb20 polished rail and injectors SOLD
  • 4 weeks later...
  • 2 years later...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
