33 ones don't :O
I got hold of a 3.5" Nismo system from a '33 GT-R, and the mufflers were both centre-flow, and the angles were all wrong (the length was too, but I expected that).
Some of the pipe was re-used, but neither of the mufflers were suitable, so it turned out to be pretty much a custom system.
Anyone want a genuine Nismo rear muffler suit R33?
:rofl2:
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4835982
just get one made at an exhaust shop, cost me $400 fitted for a mild steel 3" catback with resonator and cannon, dropped the car off in the morning picked it up in the afternoon
Was that loud? Mine needed 2 mufflers before it was quiet enough to drive without getting a headache from the drone in the back - although that was with a turbo-back 3" stainless system.
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836205
yeah its pretty loud, plan on putting another resonator in to quieten it down
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836225
I've got two big oval mufflers in my system (magnaflows) and it still drones from the back... though it was pretty *#$%ing loud after I fitted my dump pipe and it didn't line up with the cat, driving it to the exhaust shop with only one bolt in and a big gap between dump pipe and cat...
Edited by DaveB
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836265
Yep saw the super drager one at $650 and thought it was too dear so got one made up at an exhaust shop and ended up costing over $800! (Another SDU member has since bought the super drager)
Apart from the one in the link above other importers will be able to order a Stagea specific exhaust for you.
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836616
3" turbo back. no mufflers or resonators and I think she sounds like a gem! lol
haha yeah sounds a bit like a tractor off boost though... don't even know what on boost sounds like 'cause i never tried when mine was like that...
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836651
I used a 32 GTR cat back also. 3" stainless dump ($150 off 33 on here), EXTREMELY high flow cat :D , $70 for cat back 3 1/4 " mild steel cat back one resonator+oval muffler, $70 to mod it to fit. = 290 Turbo back ;)
Jeez you did well. I did the same but I wanted a new or near new good quality stainless system.
I just bought a second hand 32gtr stainless 3" cat back for $250 (was pretty much new). He had a stock S2 stagea zorst there as well and when we lined them up they were pretty much exact however the 32 one was about 10cm shorter and obviously had lesser gradient bends.
So I took that plus a new jjr split dump/front and a new hi-flow metal cat to Rob bliss. It's getting fitted up as I type. I'm hoping it'll all come in round the $750 mark for the whole lot fitted.
Definately not the cheapest option, and I probably could've shopped round for a bit longer. But for practically a new high quality full turbo back stainless "3 system I reckon that's pretty good value for money. Still cheaper than buying a package.
Can't wait to see/feel/hear the results.
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4839823
The zorst is all fitted up. There's a noticeable power increase, my mate said "that's the biggest increase he'd felt in an exhaust mod".
Mind you it did go from stock to full 3" stainless turbo back with a split dump/front and 100 cell highflow metal cat.
It's definately louder, not too bad tho. Just a little drone at 2-2500rpm, but it's fairly silent when just idling along.
Back to the topic question tho;
They didn't have to bend the pipe, just had to move the brackets and extend it by roughly 100mm.
The split dump/front was for a 33 and didn't require any bending and wasn't fouling anything. However mine is a RWD which I think means there is less gear in the way up front??
There is slightly less ground clearance (to be expected), but it's a minor difference.
He did say that he was glad I bought quality gear tho, because he gets some people bringing in dodgy cheap crap that doesn't fit and they want it to be fitted for nothing.
So yes 32 exhausts will fit with a little modification.
Cheers,
Dave-
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4841902
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
