I am putting this up because I have decided that i want a change for either an S15 or maybe an R34 gtt this car is an excellent car to drive either on the road or on the track. All of the mods have been done profesionally and only top brand name gear has been used i.e the Endles brakes are worth $2000 alone, it is mod plated and registered untill January next year.
Please no test pilots as i work a very hectic schedule and have no patience for time wasters
Mods:
1jzgte
HKS T04S Turbo (Rated at 550hp)
4 Inch inlet
HPI Stainless Steel Manifold (T4)
HKS 40mm External Wastegate
Screamer
Sard 550cc Injectors
HKS Camgears
Power Enterprise Super Strong Timing Belt
HPI Engine Dampener
HPI FMIC with Aluminum Piping
Greddy Type R BOV
3inch Turbo Dump Pipe
3.5 inch exhaust high flow cat, one resonater and twin stainless pipes (sounds fat).
Sard Fuel Pressure Regulator
Alloy top pipe
Senders for guages.(oil temp, air fuel, water temp)
Battery relocated to the boot
Pollished rocker covers
Braided lines
Catch can
Pod filter
Engine and Fuel Management:
Greddy Profec B Spec 2 EBC
Greddy Emanage Blue with all optional harnesses (injector & ignition)
Walbro 255L/HP Intank Fuel Pump (High Pressure)
Tuned by Cihan Aday from Etuner.com
Drivetrain:
R154 gearbox
NPC (Nick's Performance Clutches) 5 Puck Cushion Buttoned with Modified Pressure Plate of 3500lbs
Nachi Throw Out Bearing
Suspenion and Brakes:
HSD Type HR Coilovers with Height and 16way Damper Adjust
Endless 2 Piece Slotted Front Brake Rotors
Akebono Street/Sport Brake Pads (Dustless)
Wheels:
18* 9.5 New drift teks (polished lip) +18 offset
Interior:
Cusco 7 point roll cage
Recaro SR2 Reclinable Bucket Seat (Driver Side Only)
Momo Steering Wheel
Vertex Gearknob
Vertex Shift Boot
Vertex Parking Lever Boot
Pioneer Mp3 CD Tuner
Pioneer 3way front Speakers
Located on the Goldcoast
Price: $21000 NEG (Throw me an offer if you are keen the worst is can say is no) or prefer swap for an S15 or R34gtt (Car will also come with a Full TRD lip kit)
If you have any questions call me on 0407626786 (better than sending me a pm as i can get back to you faster)
Will get better pics up soon. (PHONE PICS LOL)
Edited by Peteman
bump and will let you all know how the new Trust turbo goes when it is on the car (hate waiting lol) and i am neg so throw me some DECENT offers as i have found a car i like and it is still for sale :P
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
