  • Replies 181
ok guys if you are reading this please give your opinion im looking in to all the part for the gtr's suspension
im stuck in what to get.
i dont have the buget to run with the Ikeya Formula stuff so what should i do????
do i go with the JUST JAP stuff or with say CUSCO stuff like everything?????
please i need help
I'll pm you the good info and am with Bris! To much money gets wasted in wanky susp for club cars.
Just copy my car. Has nothing to fancy and does pretty well for what it is. Cusco fixed upper arms 3.5deg, adj Cusco rear uppers, tien castor rods and whiteline swaybars with bilstiens. Get the fronts for about $250 secondhand, rears prob $200. Swaybars $500 new. Castor rods $150ish. It has never put me in a bad situation. You having never driven a gtr hard it going to take at least prob 10 trackdays before you even begin to understand how to steer the car let alone touch the susp.
Better than putting $5000 susp in your car you can't understand. The extra trackdays you could do with the money you saved would be more benifitial. I don't get how so many guys do one track day with maybe 25 laps in groups of 3 laps where ther car only does 2 fast and then say they need to take the car to the workshop because it doesn't handle right. They prob haven't even learnt how to drive the new setup! Don't get caught in the cheque book racing.
I was talking to your Dad at the Aust Supersprint Champs about this, it sounded good when he said rotisserie!
I have the following suspension on my R32 and it will run 47's at the Island no problem....
Front:
Nolec Adjustable upper control arms - unfortunately I don't think these are made any more, but worth a look
Cusco castor rods
Whiteline 24mm Front bar
Tien RE shocks that have been revalved
650 lb springs
Rear:
Tune Agent Upper control arms and traction rods - mostly for easy adjustment and to replace the old factory stuff that is about 15 years old
http://www.tuneagent.com.au/public/merchan...gory.aspx?id=84
Whiteline 22mm rear bar
~450 lb springs I think
The HICAS is still in place
Nothing too over the top and have found all parts bullet proof after 5 years on the track and about 10,000 road k's.
Regards
Andrew
i wish my old man liked my car just a little... its always jap crap get a real car like a commodore. then we pull up at a set of lights and i spank the bommodores ass harder than my house maid
well time to update,
Christmas has passed and now time to get back on track!!!!!!!!!!!!!!!!!
with dad clipping me tell me to get back in to it this is what we have done this weekend.
photo of stuff going to be blasted
the rear sub frame out and painted
gear box mount to be washed and cleaned before painting
stuff being painted
more of the stuff painted
and now that looks much better
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
