I've got an R33 GTS25t coupe, have 17x9 rims on the rear with 255/40 rubber. Suspension is tein height + damper adj coilovers, at the moment the gap between the top of the tyre and the guard lip is ~25mm, i hope to lower it about a further 20 - 25mm if possible so the guard sits just above the tyre or almost level. I have 235's on the front.
Does anyone have a 33 with 255s on the back that is pretty low? Did you have to pull out the inner plastic guard on the front so it doesn't rub when you turn? Also im guessing the rear guards will have to be rolled, anyone got their rear guards rolled successfully on a 33?
:P
Chris.
https://www.sau.com.au/forums/topic/28975-slamming-r33-gts-with-255s-on-rear/
Mines a bit lower and is running IMPUL 3 piece on extended width hubs. Take a look at the red 33 on the www.rwdturbo.com sandown track day pics. It's not as low as you might want but I do drive on the street and need some range of motion for decent handling on the track (non adjustable tein coilovers). Then again the offset may be different. I didn't need rolling and the fronts (235) are also cool.
Ive got Volks 17*9 with 255/40/17 and running Tien suspension set on the lowest. It has never rubbed, not lips but was certainly close, but due to the rock hard suspension, there wasnt much travel. I have since raised to the highest setting, yes it looks ugly, but only as i got a canary.
ok thanks skylinegeoff, do you still have your plastic inner guard in? i guess ill just take mine out, my front 17x8 (235's) have spacers so they sit right out but just inside the front guards. my car looks about the same height as yours, maybe a few mm higher at the moment.
Robo's yeah my sus has hardly any travel either, are your guards rolled?
you able to post some pics or pm me, of your car when it was lowered? also how did u go passing EPA with your loud exhaust? :D
i had 265's on my old Gtst.. it had plenty of room.
You'll also inherit some nice neg camber when you drop it more, so the tops of the tyres will sit nicely inside the guards.
Christian
I've got exactly the same as you....Tein's...17's.....255/40.....235/35. I have all the guards rolled...about $65 each guard. Mine only rubs when turning/dipping, such as exiting my drive (but only at certain angles). Mine is pretty slammed, (see avatar) I can measure if you want.
cheers Ozzy
Boost
Ive only got the pic in my avatar on how low it was. At the moment there is a fair gap at the back, so no use sending those, soon i will drop it back down a little.
About the loud exhaust, its amazing who you know in the exhaust industry, so the letter has gone back to the EPA with below 90db.
TO all,
I run 18x9(fr) with 245/18, and 18x9.5(Rr) with 265/18/35 on simmonds le wheels.But be warned dont dump it any lower than 10 to 15 mm above tyre as the ride gets way too harsh,doesnt do the car much good either and you will need to fit a camber kit to get any mileage out of these,as the lower you go the more neg. camber you induce.
Regards,
SKYLINE...
skyline
are your front or rear guards rolled? im interested in knowing whether it's necessary, since this is the next step to consider if i am to lower it more. yeah got a fair amount of neg camber on the rear as it is.
Ozzy that would be cool if u could measure it :cheers: and u guys got any pics that show the height?
cheers
chris
Boost, offset is the most critical factor when lowering. A difference of 3mm offset may make the difference between rubbing and not. I am running 18x8 +35 with 235/40/18 and 18x9 + 35 with 265/35/18. The rears are very close to the outer guard (nothing rolling won't fix), but due to stock ride height, they don't rub. The fronts are absolutely fine, could be dropped a fair amount. Be aware though, that a 18x9 +35 might sit differently to a 17x9 +35. Not sure if that is really helping, but my guess would be if you are running 255s on a 17 with the correct offset it should be OK.
measured to bottom of guard lip mine is 645mm off ground all round and 345mm from centre of wheel to guard lip. probably as i said before drop it another 20mm, dont wanna get my guards rolled if i dont have to but this may be the only way. the guard lip on the fronts dont stick out as much as the rear, so they may not need to be rolled?
Boost, you really should roll the front, because the time you will rub (possibly catch and pop your guard out) is not when you are going straight, but when you are turning and the suspension compresses. The tyre may catch the metal guard and pull it out - happened on my old car. If you are going to get the back done, get the front done at the same time ;)
BOOST,
Sorry for delay in getting back to you, i ran out of internet hours on sunday nite.Yes my rear guards are rolled,nothing on the fronts.My ride heights are 350mm fr,and 335mm rr, with -1.5deg rr camber and -1.5degfr camber,caster set at 7.0deg and fr toe at 0 with rear at 1mm toe in.The total car weight is 1448kg with corner weights at lhf 394kg rhf 393.5kg lhr 335kg rhf 332kg .Getting these corner weights this even is one of the advantages of running coilovers because you can adjust the corner heights of the car to achieve different weights and even up any discrepensies you may have.The weighing of the car was done on race car scales and done here in adelaide by manta racing (steve cramp )
Regards,
SKYLINE....(kym)
  • 8 months later...
Yes we can do it a one stop shop for panel paint, Dent Removal, Buff mark Removal, Paint Glazing.
Please see www.clik.to/glassplexin or follow the link to DentCraft
Proudly Sponsered by DentCraft.
I can do mobile if needed but must have suitable area to work on.
Des Wong
Glassplexin WA
0412 034 861
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
