As the topic indicated i have misfire at about 5.5k rpm and have got a second coil pack that i want to fit. However i only want to change the faulty coil. How do i diagnose which is the faulty one?
I would rather not run the car 5 cylinders red line the crap out of it
Any ideas?
Thanks in advance
https://www.sau.com.au/forums/topic/289958-help-me-diagnose-my-faulty-coil/
Usually the problem is a hairline crack in the coilpack body which allows the spark to follow the path of least resistance and arc to the head. Remove coil cover, move car to a dark place, start car, get someone to rev it while you try to spot which coil is arcing out....replace.
Moodles2 can you please elaborate on your post. You saying to buy a cable and run it from the ecu to the COMP and i need the program? Where can i download/ buy the cable?
I'm not sure if it will spit out any fault codes cause the check engine light doesn't come on, it is only really mild miss fire but still need to fix it!
If you have an R34 - Better get a set of new coils (splitfire brand). Once one coils starts to fail the others will not be too far behind.
Best get a new set it will save you hassle especially if you drive far from home alot.
This only applys if you still have the stock ECU. Your Skyline has a fuse box under the steering wheel, inside is the Consult port (aka diagnostic port). With a Consult USB cable (http://ecutalk.com/interface.aspx) you can connect a PC or laptop and read sensor values, do active tests etc as long as you have PC software like OBD ScanTech (free) or Nissan DataScan (commercial), this is a screen shot of Nissan DataScan (commercial version not the cut down evaluation version) with the page to cut off spark to cylinders, effectively disabling them.
the problem with using the consult method is it isn't that reliable for what he wants to find out. at idle the weak coil may be firing fine and simply switching of cylinders won't find the dodgy coil.
swapping the coils out 1 by 1 will give the most accurate results, however if more than 1 coil is failing then it won't help much.
also, before you start swapping coils around, how old are you plugs, what gap are they, what heat range and what type are they? if you plugs are getting old and worn then they may be the problem and not the coils. in my case when i had a missfire it was caused by the plugs and not the coils.
far out i'm confused! lol yer well tonight i'm gonna pull it all apart and see wats happening under there :thumbsup:
Only problem is that it doesn't constantly miss! Last night on the way home it was running fine on full bost and the the red line, but the day before it was missing!
is the r33 series 1 coil pack the same as the series 2?
Edited by P1OTR
s1 has a seperate ignitor pack (same as r32). series 2 have it built into the coils (same as r34).
Thats right, I put r32 gtr coils in mine wen I had a miss. But does that mean all rb26 coilpacks are the same? or will the r33gtr ones be like the series 2 coils?
so in short i can't put an series 2 coil in a series 1?
nah man u cant, they simply wont ignite.there will b no connection.
series 2's hav their own igniters on each coil pack but a series one only has the one firing up all 6
the r33 gtr coils i have seen were like the s1 and r32, but i don't know what year series gtr it was.
ah true,,how many series 33gtrs are there? and wat r the differences
I have a set of s1 coils somewhere, what side of town are you Peter.
hey, he's mate of mine, he's down Narre side.
Ey Piotr,i got 4 good spare coils if u need, but if ur closer Madbung, go ahead
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
