First test drive proved very enjoyable. Driving a big stalled auto is definitely a lot different to a manual setup.
Saturday Night Roll Racing at Queensland Raceway back on the 14th was the cars first event. Anyone not familiar with this event up here, it's an awesome and relatively new social racing event similar to a happy laps or powercruise session. People line up in the staging lanes and in pairs roll around to the main straight and drag each other. The nights very social and is as fun off the track as it is on the track.
a few days prior to the event I got a fabricator mate to pop around and we had some late night fab fun putting a side pipe on the car. Personally I think it turned out awesome. Bolts on and off just after the gutted cat is tucked up high on the car for good clearance.
A2B4CEC3-EB4A-404A-9788-383FB88F6E6F_zps
Here is the side pipe when its off the car
0684DA69-87CD-4030-8C02-C3C781128137_zps
Some of it on the car
F7BDEDA5-C558-44B0-9E0D-67BE75C1740B_zps
FD22848F-8A5F-474B-AFA8-8D0E747BE2AA_zps
Now for the idle video!!
  • Like 1
Now it was time to actually take the car out there and have some fun with it. To be honest I was more nervous than I thought I would be, it was excited nervous but nervous all the time. Took the first few runs relatively easy just to get a feel for the new setup and how it would react, specially the gearbox.
Mates got a video of the maiden run for the car. Wins a win even if its not overly fast
  • Like 1
Took a mate for a ride later in the night and got an in car video of a race. As you can hear 2nd gear is a bit of a write off as it just wanted to break traction and get loose. New to the setup I decided it best to get out of it and back on it rather than drive though it.
All in all the night was awesome and got a great felling of accomplishment finally getting the car out to an event. Few teething issues here and there to sort out like any brand new build but all in all a successful first night out.
  • Like 1
What power is it making on e85 again?
Currently tune is very mild. 500rwhp at 25psi. TH400 is a power sucker, however the cams that are in the head are too small for the size of the turbo and we arent seeing good enough gains per PSI of boost we are adding so we brought it back to have fun at the track last weekend.
Cams are In:264 Ex:272. Inlet is the big killer
Turbo: 80mm Billet Turbocharger
  • Like 1
More info on crank trigger setup please.
Some good photos of it a few pages back.
Both cam and crank triggers use Honeywell GT 101 sensors. There is also a small 12 tooth trigger wheel that sits between the balancer and the timing belt cog
  • 3 weeks later...
Pretty quiet on the car front for the last few weeks, busy moving house and life in general.
Contemplating a few different things to change on the car. Typical RB life has me pushing decent amounts of oil into the catch can. Thinking of putting on a "Pre catch can catch can" i guess you could call it. Here is a few mock up pics of what it would be. Hoping that gravity helps keep at least some of the oil inside the covers lol
C5194459-8246-4942-A86E-EFF4CB7F1901_zps
4A533956-FD9E-44B1-A379-F02FF61E4F5A_zps
174C7A81-788B-4F8B-9583-7E793D50E6CD_zps
  • 6 months later...
    • If the gases flowing in those two tracts had the same properties, you could maybe use such broscience. But the exhaust has a different composition, different normal density, different actual density (because of different normal density, and mostly because of the massively higher temperature), and different viscosity (again because of much higher temperature). Consequently, all of the fluid dynamics parameters that matter, that you calculate from these inputs, such as the Reynolds number, friction factors (for wall friction) and so on, are all incomparable.
    • And we shall have to presume that Canada is the same?
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
    • I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves. So you can seal it up and get nice cold air which IS good, but at a certain crossover point: More Hot Air > Less Cold Air I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
    • Nah, the OEM CAI pipe is still installed behind the bumper, it is about 5" x 3" oval at the engine side, tapering down to a 3" pipe behind the bumper where it gets all the ambient air it needs Engine side of radiator support OEM intake pipe "oval hole" that is right in front of the filter My OEM NC1 CAI pipe: From NC2 onwards, below pic, they come slightly smaller at 2.75" diameter with corrugations and a resonance chamber to reduce intake noise, lucky for me my NC1 has the bigger noisy one, LOL   Basically, the "sealed" airbox will just get ambient air from a 3" pre filter intake tube that is the same size, 3" as the rest of the intake pipe post filter, and if a 3" intake isn't big enough to flow enough air for 150 killerwasps then there are other issues The whole intake is basically the same length as OEM, but it is now about 30% bigger from the airbox back through to the new intake plenum than OEM, and the intake plenum is port matched to the head And the intake is now about 30% bigger than my 2.5" exhaust, so the suck, squeeze, bang and blow black magic should be fine, well, to my uneducated understanding of fluid dynamics anyway Talking the the guys at MX5 Mania, it may even make a few more killerwasps as the intake isn't sucking hot air, especially off idle or when in slow traffic when it would be sucking hot air  As for the difference in IAT, I haven't logged IAT yet, as I don't currently have a OBD2 reader, but I will have a play with my thermal lazer thingie next time I take the car out to sèe how hot stuff gets under the bonnet near the intake filter prior to installing the air box, my "assumption is it has to be much better after the air box is in and sealed up compared to what it is now The aftermarket "performance" CAI elephant in the room: Aftermarket CAI intakes typically have the air filter tucked up behind the bumper, with a 2.5" intake tube (the OEM intake pipe is actually about 30% bigger than the fancy pants "aftermarket" version.....WTF), and you need to remove the bumper to service the filter, which is a PITA Like dis:
