results are in.
Blue us RB30 orange is rb25. full comparison and nothing else has changed except the bottom end.
turbo is 3076 56t with 0.63 rear... falls over pretty hard and adding more boost doesnt increase it.. so rear is a restriction thats for sure. Need a .82 rear for it.
didnt have any issues with the car apart from oil pissing out the catch can due to the sump being 2L overfull... after spewing oil out several times and filling the can its finally reached a happy level where it wont do it any more haha. still a fair bit above the H mark too. i now have a massive mess in the engine bay which i need to clean confused.gif
in terms of power and performance... wow.. its like night and day. can leave it in 3rd in the esses, even if following someone and you have to adjust your line in the entry to a slower one you can back off.. get back on the throttle and it just spools straight away haha. exiting the esses you can shift straight to 4th and it pulls HARD up the straight and just bakes 1 and 2 in 4th. loves it!
have a slight oil pressure related issue... not sure whats going on. have a read here if you care http://www.skylinesaustralia.com/forums/topic/405788-oil-pressure-dropping-when-no-load-on-engine/page__fromsearch__1
all in all... decent shake down. plenty of grip with the rear DW knuckles in now.. not a fan of the front DW knuckles. i wouldnt recommend them to anyone thats for sure. as a drop spindle they are wicked but for big lock with no bind... nope they dont tick that box. I will be cutting and shutting (in a not so dodgy way) and repositioning the tie rod mount on the knuckle so its more in line with my modified knuckles that i do. It should be easy enough to do due to the construction of the DW knuckle as its just made out of welded plate steel. I wont do it before WTAC as theres to much to do and EC isnt a big angle entry track anyway so worry bout it when i get back.
good results
would have expected more kw power with the extra capacity and higher comp ratio
seeing that camshafts alter power band, no chance that changing shafts to suit the 30 while keeping the 0.62 rear would increase power with more psi ?
just a thought
WTAC run and done.. just got back 3am this morning so im running low on energy.
full write up coming soon.
25 dollar bottom end loved life. smashed limiter and shredded tyres. Missed out on top 16 battles but won the bottom 16 battles beating the NZ guy who won it last year so reasonable effort!
car's a bit smashed up.. quick vid here
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
