A lot of people blab on about how their gtst are 'stock'
yet they have 3inch exhuast. Really is this stock?
Can you compare a pure stock vs a stock + 3inch exhuast?
the car with the exhuast will win provided both drivers equal skill level.
i have a pure stock nothing done expect a K & N filter. Yet i've bet many other stocks with 3inch exhuast. Shit driver? probably.
Any way my MAIN quesiton is, has anyone here who are PURE STOCK
boosted their car with bleed valve. YES pure stock NO exhuast but boosted say 9-10psi?
ANYONE?
https://www.sau.com.au/forums/topic/29151-what-is-stock-gtst/
Hi mupkant, perhaps the reason you are not getting much response is because what you are suggesting (boost up & no exhaust upgrade) is pretty silly. The standard exhaust on a turbo car is always the weakest link, improving the other links won't help. ie; you are already choking the turbo with the standard exhaust, so turning the boost up is pretty much a waste of time.
Plus, in my opinion, you are risking ceramic turbine failure earlier than if you upgraded the exhaust. This is because strangling the turbine does not allow the heat to escape and heat will kill the ceramic just as fast as excessive boost will.
Maybe that answered your question, in a round about way.
hehe yeh my car was completely stock when I got it. As in factory stock. The exhaust even had the date & month of the car's manufacturer stamped on it. No air pods, boost controllers. Took 11months for the importer to find a good condition factory stock 32. Only thing aftermarket was a Addzest aftermarket headunit.
Anyway i did what Sydneykid was talking about - stock car with more boost. Sure it gave it more power but you could definately feel the exhaust choking everything. Car now has 14psi boost, 3" 5Zigen dump-pipe back exhaust & remapped ecu. Funnily enough its a lot easier to drive because the power comes on sooner due to the exhaust. (I have dyno graphs of what each mod did)
Anyway yes, I have talked to lots of ppl who also tell me "yeh my car was stock too, all it had was 3" exhaust, pod....".
Yeah, mine is exactly what you described, dead stock except for bleed valve. (yeah, I know, that makes me an idiot :D )
It runs about 9-10psi.
For me exhaust note is a concern, the stocker is nice and quiet, its a daily driver and I hate droning exhaust.
Also, to me, I reckon a stock skyline is plenty fast enough for a road car, I'd rather learn how to make the most from a slow car, than to drive a faster car poorly...
Only other "performance" mods are 18" wheels and a tighter diff. Which makes mone pretty much the slowest GTST going around :)
my car only has a a 3" front pipe and dual cat back sys and im not surprised that stock as a rock lines will probably beat me....though no one has yet:D:D i find that with the exhaust u loose the kick when the boost hits at 2.5k but when it hits the 5k mark when full boost is on then its a different story:D
are u planin to run 9-10psi mupkant?? apparently u can get about 9psi by just gettin a full exhaust system??
mupkant,
No problems doing the bleed valve first. The exahust is always a good thing but, if you got no $ then the $90 for a bleeder is cheap and gets rid of the 'two step' boost of the factory controller. You can always keep the boost down to 10psi to save the ceramic turbine.
It works. so go do it.
mate, second thing I did after my bleed valve was the exhaust and I tell u what. Its quiet as anything. No in cabin drone at all and its even fairly quite at high rpms.
U just have to make sure you get a well designed one. Thats why I got a jap brand Jasma approved one. (5Zigen) The damn thing is so quiet i'm thinking of getting rid of one of the mufflers!
Mine is completely stock besides the K&N panel filter, turbo timer, and 2 stage boost controller. I bought it with the controller & timer on it. I have kept up with 32s only having like a cat back system running pretty much equivalent boost & same with 33s, but i have been hosed by a few running decent exhausts & being well tuned. It is running around 11psi. I think the previous owner should have focused on the exhaust first. Early next year i am getting a custom 3" turbo back zorst, along with heaps more goodies....
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
