I've got he HPX all round on the the wrx, very happy with them, good cold stopping abilities and seem to handle some good hard street stops.
Will be doing to the a1rm on the skyline when its ready to come back out to play
  • Replies 14.2k
front page of the australian.
THE navy's $6 billion Collins-class submarines face serious operational restrictions after being hit by a run of crippling mechanical problems and troubling maintenance issues.
ok so we need some help guys, whats the biggest turbo hks make? anychance there is a RB30,000 kit?
according to the australian our swedish engine is no good :) musta been the boost controller i installed and upped it to 400psi
Edited by Inline 6
try ebay..or racespec..same thing :)
Well had my first run in with SAPOL in the GTR today. Got pulled up on Fletcher Rd by one of these but a little older. Had surf boards and all on the roof racks and even a "UNIT' sticker. Pulled me up because I wasn't the registered owner of the car (but I had changed it yesterday). Let me go with "Just be careful for me mate"
Did it have police insignia and sirens? With surfboards? Dude show u his ID ?
-D
Yeah Dohmar. He even showed me the screen saying it was still registered in the old owners name. I didn't even believe it. I even said to him "man thats sneaky as" he just laughed and replied with a "We gotta keep you young ones on your toes"
YAY ABE IS HAPPY :ermm::blink:
Got my car back today, runs like a dream. It is now making 265rwkw @ 15psi and 2 degrees extra timing. Full boost is seen at about 3.5k-4k, it is a little laggy for my taste but means i cant exactly mess around as much, so fuel economy should also be good too. However, once boost kicks in....you know it :( .
Whats it got;
Nismo 740cc Injectors
Garrett GT3076R (3037S) with 3" Front/Dump and 3" Magnaflow Hi Flow Cat.
Haltech E11V2
Turbotech Boost T
NGK Iriway7 Sparkplugs
Superspark Coil Packs
Also had the timing belt and accessory belts changed as well as the belt tensioner and spring, oil, oil & fuel filter changed, water pump and seal changed, also the front crank oil seals too.
Dyno Sheet
Edited by Aberax
Whats it got;
Haltech E11V2
Turbotech Boost T
Dyno Sheet
Excellent result... those Haltechs are a serious piece of kit
Makes me wish I had my turbos already, I have got some siemens-deka racing injectors on their way but only 575... I won't ever be needing bigger while the car has N1's...
(and the injectors cost $360 aussie from the US, and that includes shipping. i love the near-parity... great time to buy from the US..)
soon as they arrive, I'm gonna buy some isc camgears and have my mechanic tune it all
-D
nice power curve u got there mate
did u get a print out of the air/fuel ratios??????
I am a bit of a noob when reading Dyno Graphs...but i believe it is the dotted line on the graph i posted. I think it starts off at about 13:1 and then goes to about 11:1 towards 7000rpm.
Edited by Aberax
that looks like some kinda ratio AFR:P, so what is P ??!?!? becuase its all over the place as far as a straight /normal AFR map goes...
I don't think the AFR's are supposed to be too linear.
Anyway, for comparison, here are the Dyno sheets from earlier in the year when the car was more "stockish"
Power/AFR
Power/Boost
And maybe later i may post pictures of my engine bay.
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
