I've got he HPX all round on the the wrx, very happy with them, good cold stopping abilities and seem to handle some good hard street stops.
Will be doing to the a1rm on the skyline when its ready to come back out to play
  • Replies 14.2k
front page of the australian.
THE navy's $6 billion Collins-class submarines face serious operational restrictions after being hit by a run of crippling mechanical problems and troubling maintenance issues.
ok so we need some help guys, whats the biggest turbo hks make? anychance there is a RB30,000 kit?
according to the australian our swedish engine is no good :) musta been the boost controller i installed and upped it to 400psi
Edited by Inline 6
try ebay..or racespec..same thing :)
Well had my first run in with SAPOL in the GTR today. Got pulled up on Fletcher Rd by one of these but a little older. Had surf boards and all on the roof racks and even a "UNIT' sticker. Pulled me up because I wasn't the registered owner of the car (but I had changed it yesterday). Let me go with "Just be careful for me mate"
Did it have police insignia and sirens? With surfboards? Dude show u his ID ?
-D
Yeah Dohmar. He even showed me the screen saying it was still registered in the old owners name. I didn't even believe it. I even said to him "man thats sneaky as" he just laughed and replied with a "We gotta keep you young ones on your toes"
YAY ABE IS HAPPY :ermm::blink:
Got my car back today, runs like a dream. It is now making 265rwkw @ 15psi and 2 degrees extra timing. Full boost is seen at about 3.5k-4k, it is a little laggy for my taste but means i cant exactly mess around as much, so fuel economy should also be good too. However, once boost kicks in....you know it :( .
Whats it got;
Nismo 740cc Injectors
Garrett GT3076R (3037S) with 3" Front/Dump and 3" Magnaflow Hi Flow Cat.
Haltech E11V2
Turbotech Boost T
NGK Iriway7 Sparkplugs
Superspark Coil Packs
Also had the timing belt and accessory belts changed as well as the belt tensioner and spring, oil, oil & fuel filter changed, water pump and seal changed, also the front crank oil seals too.
Dyno Sheet
Edited by Aberax
Whats it got;
Haltech E11V2
Turbotech Boost T
Dyno Sheet
Excellent result... those Haltechs are a serious piece of kit
Makes me wish I had my turbos already, I have got some siemens-deka racing injectors on their way but only 575... I won't ever be needing bigger while the car has N1's...
(and the injectors cost $360 aussie from the US, and that includes shipping. i love the near-parity... great time to buy from the US..)
soon as they arrive, I'm gonna buy some isc camgears and have my mechanic tune it all
-D
nice power curve u got there mate
did u get a print out of the air/fuel ratios??????
I am a bit of a noob when reading Dyno Graphs...but i believe it is the dotted line on the graph i posted. I think it starts off at about 13:1 and then goes to about 11:1 towards 7000rpm.
Edited by Aberax
that looks like some kinda ratio AFR:P, so what is P ??!?!? becuase its all over the place as far as a straight /normal AFR map goes...
I don't think the AFR's are supposed to be too linear.
Anyway, for comparison, here are the Dyno sheets from earlier in the year when the car was more "stockish"
Power/AFR
Power/Boost
And maybe later i may post pictures of my engine bay.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
