  • Replies 14.2k
.82 rear, thats why its a bit laggy, but u got more topend out of it
since u cant check ya knock level reading just keep an eye on ya engine warning light, if it starts to come on regulary after a boosting hard step off and getnya tuner to check everything again (timing)
I am not really fussed, still picks up speed quick, boost hits like a train...which is rather interesting, first few times i did it, it was like when they hit the NOS in Fast & The Furious :) .
Since it is more laggy now, does that mean i am going to get better fuel economy when just dribbling around town?
Not so much at 160km/h but the revs at which point on this garph it hit 160km/h if you know what I'm saying.
yeah I was only using kph as a reference for the graph....load on the road could lean it out at any speed
As a rule of thumb 14:1 at idle, and depending on your timing and amount of brake on the rollers 12:1 is the leanest I'd ever go up top.....11.5:1 is a bit safer as long as everything else is taken into consideration.......we're talking pump fuel by the way.
mate dont worry i no what its like to have a laggy turbo and thats on a forged eng. i have garrett gt3540 on mine
and like yours when boost hits it hits HARD!!!!!!!!
i love it
ahhahha my fuel economy is shit and thats rarely boosting it
I am not really fussed, still picks up speed quick, boost hits like a train...which is rather interesting, first few times i did it, it was like when they hit the NOS in Fast & The Furious :thumbsup: .
Crank up the boost to 18psi and feel the hit :)
buy decent quality straight off the bat. please. save for an extra week or 2 and buy cusco's or something.
It has been suggested on these very forums that the BC coilovers come out of the same plant as the Greddy coilovers. I'm not entirely sure whether it's true or not.... but either way the BC coilovers have springs that are too stiff for my liking!
I really do wonder, what exactly drives people to do this.
Also, why 49?
Doesnt help when your girlfriend posts what you've done over her Facebook status updates like Dan showed us!
i think krish is making similiar power to you abe. about the 250rwkw mark.
Yep making around 246.6 rwkw on 14.5psi....needing a new exhaust as when we cranked the boost up to 17psi at 400rpm it starting dropping off to 14psi and held hard on 14psi....for some stupid reason the boost wont go higher then 14psi so we ie me and the tuner came to the conclusion of needs a new cat back system and also have to get andrew from AM Performance to fit it all up as there is a leak out of the vband flange thingy
I am using a .63 rear housing so my boost comes on a bit earlier then yours Abe but has the same feeling of hitting you like a damn train when the boost kicks in.....well described with the FnF NOS scenario....cant wait to check it out tomorrow
mine is at boostworx right now, tuning the AEM FIC-8 ecu.
235kw at 5850rpm but not reving past 5850 at all - Im sure its a setting in the program,
I have made my suggestion re calibration to the tuners, so hopefully a little later I'll get the good news that all is fixed and well, reving thu to 7250rpm as per the remap chip.
the AEM FIC-8 looks great: here http://www.aempower.com/files/electronics/...lease080728.exe
for $350 off ebay its a massive score, considering the safc/sitc sold for $300 before they were even off the car! ;)
Hopefully my thoughts re the tune program setup work, and she free revs again into the red zone.
250kw
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
