  • Replies 14.2k
hot week next week, unfortunatly my aircon compressor bearing is siezed, any ideas on cost for repairs?
My aircon compressor clutch is fecked, been like it ever since I bought it. Got quoted roughly $450 for a s/h compressor, fitting and gassing from Jaustec.
thats who i was thinking of going through, how long ago was that quote done?
think i might go without it for a while longer then, haha.
ITS ALIVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Finally good to see Mitch...i am guessing that you haven't hooked up the stock boost gauge line either?? and as far as i know there should be a connection for the oil pressure....ahh well just get aftermarket gauge that will prob be more accurate
took my R31 to a place in lonsdale on o sulleys rd near the old ASV building who fixed the leak , new condenser and swapped out the compressor for about 300 all up including regas,top work for cheapest I could find around the south.
gotta love the ole UFC Damo......NOT for the faint hearted though (I know Carl - Bezender would agree with me)
I'd love to go toe to toe with a couple of the serial pests on these boards....may even teach them a little respect for the old fellas, lol :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
